Question about Kenmore Dryers
How to remove control panel from kenmore front load dryer model 110 65962401
4 Suggested Answers
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Remove front panel - no heat and buzzing sound
Hi, If the lint screen is at the top of the dryer, remove the screws located at the lint screen. Then pry the top by inserting something flat into the gap between the top and the front panel. Now locate the screw inthe upper inside corners and remove them. Now the front will lift up and release from the cabinet.
If the lint screen is inside the door, the lower half front panel will release and let you see under the drum.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 22, 2009
How do you open up the kenmore dryer model 80311900 with the front control panel for cleaning out lint
To disassemble the machine, disconnect the power!
I believe that model has two screws in the rear edge of the top panel. Remove the screws and slide the top panel to the rear and remove it. Then remove two screws, from inside the machine, that hold the front panel in place from the back. Label the wires, then disconnect them. Tilt the front panel forward, then lift the bottom of the front panel up.
Mar 05, 2017 | Kenmore Dryers
Tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
on Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Dryer Model 97078712 Will Not Start I have a Kenmore Front Load dryer Model: 970787712 that wont start. If I hold the start button and jiggle the timer it starts. Is it correct to assume...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Kenmore Dryers
The control locked button is on. I do not know how to turn it off to start my next load of laundry.
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
Thanks for using FixYa!!
Dec 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i remove the control lock
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Front load whirlpool duet washing machine controle locked light is on how to reset it?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&###%%
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Problem for Whirlpool Duet GHW9150P Front Load Washer The control lock is on. How do I turn it off?
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
