Question about Troy Bilt Tb70ss Gas Trimmer
Runs only via primer bulb
Have a TB20cs. replaced all fuel and primer lines and primer bubble and spark plug . It will start and it will run HOWEVER only if I keep pumping the primer bulb to feed to fuel.
The new fuel lines are clear so I can see the main fuel line, which has fuel in it up to the brass intake nipple, but obviously not flowing.
If it's simply clogged is there any way to clean or dissolve (possibly deteriorated pieces of fuel line from ethanols?) without complete disassembly. Are there other carburator parts that may have failed? Thanks
  • 1,040 Answers
You definitely have a fuel problem. But you will have to take the carburetor off and disassemble it. As far as other carburetor parts failing; yes , but it's probably do to old age or much use. You should first take the carb. apart and clean the all ports with a Den Tek Brush, (used for cleaning teeth), they work great for this job. The smallest particle's can keep the carb. from operating properly. Also, check for a small screen that filters the fuel. It sets down in a larger port. It can get clogged as well, or even blocked completely. If after you have done all of this and it still doesn't work, you will need to purchase a carburetor kit for unit. It will come with various gaskets, a screen, and a needle valve. this should definitely solve your problem. You will also want to change your air filter, (if you haven't already), because if it is old and dry rotted, pieces of the filter can get sucked into the carb. that you just spent an hour or so cleaning. You will then have to disassemble carb. and clean again, NOW THAT WOULD STINK!!
Good luck.
Posted on May 25, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Did this solve the problem?
    Jim
Husqvarna problems
No, it is a return line to the tank from the primer. It sounds like the hoses are reversed. The fuel should flow from the tank via the main fuel line (with the filter)( sometimes the main line is smaller than the return line) to the carb, fills the carb then to the primer bulb, and from the primer bulb back to the tank. With just enough fuel in the tank to cover the fuel filter start pressing the primer bulb. Check for fuel coming out the short hose into the tank. If instead the bubbles come out the filter and the primer goes dry try reversing the lines at the carb and/or the primer bulb and try again until you get the proper flow pattern.
Aug 29, 2014 | Husqvarna 125bvx Hand Held Blower Vac
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
Will not start
After 3 years, the fuel lines may start to decay and the fuel filter in the tank is likely to be plugged. Check the air cleaner and muffler for plugging also. Remove the spark plug and check for spark which should be blue and snappy. If nothing, try a new plug gapped at 0.020". A properly running two-stroke plug should have a light to medium tan color on the interior insulator. A black insulator indicates an overly rich fuel mix or jet setting. A white insulator is either new or running too lean which will damage the piston and cylinder if allowed to continue to run. If you get spark, pour a little mixed fuel into the plug hole and try to start the engine. If you get a few pops, then concentrate on the carburetor and fuel feed. Does the primer bulb bring in fresh fuel when pumped? If not, is the bulb itself damaged or hardened? The primer is supposed to pull fuel through the filter, into the carburetor filling all spaces inside, then out to the primer pump and the excess returned to the tank through another line. Hope some of this helps!
Jun 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
522 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
