Passwords are only known by the person who did put it in.
But most routers and wireless access point, have a possibility to reset the device and then the standard admin password will become active again. For that you can look into the manual, or even on the device itself, where it says how to reset the device and what will be the default admin pass word. Be aware, after that you have to reinstall the whole device, so if you don't have the manual at hand or not enough knowledge, please leave it as it is, if you still need the device, till someone can help you.
You need to login to the routers web interface and the settings will be in the advance WiFi section, probably a tick box.
A typical web interface can be found at the following address in your browser http://192.168.1.1/
Username usually admin and password could be password or blank or 1234 or admin. Check with manual.
Ensure that wireless isolation (or any labeled form of network isolation) is disabled, though it shouldn't be enabled unless it was manually set that way. I've also run into this issue when setting up Chromecasts occasionally, and I had to do a factory reset (hold down the small reset button on the Chromecast for 30 seconds) and repeat the setup process in order for it to be detected. You might try that as well.
To properly set up the WN3000RP you first have to push the WPS or Push 'N' Connect button on the router-WN2500RP(on the back of the router between the reset and the wired connection slots) and then the Push 'N' Connect button on the extender. It should negotiate and establish a connection between them.
