Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Dryer wont stop. Keeps spinning and heating
I have a frigidaire Gallery Heavy Duty dryer and its been working fine for the longest time, but now it wont stop and keeps heating the whole time. I need to know where i can buy parts for this dryer. I need almost everything for the timer.
Model # FSF447GHS0
  • 234 Answers
Repairclinic.com is a great site to buy parts from.
Posted on Aug 19, 2009
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
Posted on May 25, 2009
SOURCE: Need Manual for Frigidaire Gallery Heavy Duty Washer/Dryer Combo Model #FLSG72GCS0
my washer make a loud sound when spinning
Posted on Feb 11, 2010
I have a Frigidaire gallery commercial heavy duty dryer model #GLGR331AS1 it just stopped heating turns on and runs but no heat. Could it be the solenoids or the igniter ?
If the igniter glows but it doesn't ignite, most of the time, it's the valve coils, most of the other times, it's the radiant sensor.
If the igniter doesn't glow, check your thermal fuse. If your thermal fuse is good, replace your igniter.
Oct 21, 2014 | Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
My Frigidaire Galaxy Series Commercial Heavy Duty Dryer does not spin it heats up but doesn't spin. What would be the cause of that?
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Oct 06, 2013 | Frigidaire FDE336RE Dryer
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 22, 2010 | Dryers
Hello! My Frigidaire gas dryer - Gallery Heavy Duty slowly lost it's heat. In the past two weeks loads were gradually getting colder and wet until heating stop complatelly.
This is most likely a bad ignitor(can be verified by inspecting burner and ignitor with the machine running. But I would also check the vent pipes from the dryer all the way to the outside to make sure there isn't any blockages or restrictions. I would need a model number to provide more specific details.
Nov 03, 2010 | Frigidaire Dryers
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
