Question about Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP
Ice cubes melted, but items at the bottom are still cold.
I have a side by side Amana. The ice cubes at the top have melted, but the items at the bottom of the freezer are still cold. So I assume, a fan is not circulating the air, but not sure.
  • brianz100 May 16, 2009
    natty976, what's the root cause?
    Problem Solver:
  • 14 Answers
I believe you solved your own prob.. definitly sounds like the fan motor stopped.
Posted on May 16, 2009
  • Bobby Burgett May 16, 2009
    Fan motors commonly burn out due to all the moisture they are subjected to all the time.Some times they last for many many years,and I have seen motors go out on refrigerators that are less than 6 months old.They are not hard to change.It has a hot,neutral,and a ground wire.This will be where the panel in the freezer is vented,and blows the cold air out.Do you have any appliance distributers or repair places in your area?make sure you have the make and model of your fridge when you go there,and order the fan motor.This will save you service charges.
    Also they will stop when there is too much Ice build up around the motor and fan blade ,because the freezer is not defrosting properly.Sometimes the drain gets clogged,the element burns out ,or the defrost timer stops working.
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
My Amana SCD23VW quit producing ice cubes. It was one big melted mess. Also freezer will not get cold enough to freeze now. Please help.
your frig is not defrosting you should see frost on the back panel remove items from frzr and remove the back panel off and thaw the evap coil if you can not get repair person to your house it will oper normal until it frost up again, generally it will be one of 3 thing dfrst heater, dfrst thermostat, dfrst timer
Sep 03, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
On our Amana Side by Side, there is water dripping from the ice-maker bucket. The cubes were melting. It does not appear that anything else below is melting. I emptied the bucket and lifted the arm to stop...
I don't have this particular model, but had a similar problem. Check the flap to the ice chute. If it's not sealing properly it would allow warm air into the freezer and melt the ice.
I had to call for service.
Jun 12, 2008 | Amana Refrigerators
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Refrigerators Logo
108 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
