Question about Danby DWC2121BLS Wine Cooler
Danby Dual Zone DWC2121BLS temp control does not work
Hi, we own a Danby DWC2121BLS dual zone cooler. The problem is that the temperature control/thermostat does not seem to work. The compressor seems to workbecause it looks like the unit is able to cool down but the actual temperature on each side randomly jumps up and down and does not stabilize. The temperature in each zone seems to vary from 44 deg to 60 deg on its own even though we have set the two zones to 52 deg and 57 deg respectively.
ANy help wuld be appreciated.
  • 146 Answers
SOURCE: Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Posted on Dec 26, 2007
supernova278
  • 1932 Answers
SOURCE: Danby DWC2121BLS wine cooler is
About parts check the below website and it will tell you how much the part costs.It has the exploded diagram also.
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC2121BLS/3055/0169000/50031950/00001?blt=06&prst=&shdMod=
Yes once you take out the solenoid valve the refrigerant will escape and you need to recharge with new gas.You cannot prevent it from gas escaping.
Thank You
Posted on Oct 06, 2010
supernova278
  • 1932 Answers
SOURCE: dual zone wine cooler left
Please can you give the model number of your Danby refrigerator
Thank You
Posted on Oct 14, 2010
  • 5370 Answers
SOURCE: i have a Danby wine
The max setting for temperature it can be set is Dry Wines: 9 to 14°C (48.2 to 57.2°F).--------
Rose Wines: 10°C (50°F).---------
Red Wines: 13 to 14°C (55.4 to 57.2°F).-------
Sparkling Wines: 9°C (48.2°F).------
-------- Actually the temperature will get set to 32 if you change the setting.But in that case you can only store beer and no wine bottles, in that very low 32 degree temperature the wine bottles will be ruined.-------- -------- Actually its internal temp setting is made for wine temperature only.So it will automatically revert to its internal cabinet temperature setting.--------- The temperature will get set to 32 but automatically after few hours revert to its internal unit settings which is for fine.So you will have to again n again check, if the temp setting is reverted to wine storage setting then again set it to 32.Then you can store beer.------ This will help.Thanks.Helpmech.
Posted on Jul 16, 2011
SOURCE: fridge does not get cold , " E4" displayed on
change digital board in the front
Posted on Aug 18, 2011
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
If I want to store both red and white wines, what is the best way to store them?
I also had the same indecision and finally I've purchased a dual zone wine cooler. The dual zone wine cooler allowed me to maintain two distinct and separated temperature zones within the same cooler which was exactly what is was looking for, and I think this is the optimal solution for you as well.
Aug 14, 2012 | Furniture
What is a dual zone wine cooler?
Dual zone wine coolers have two temperature controls and the storage space is divided into two chambers and each chamber has its own temperature.
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
Danby dual zone wine fridge.....temperature is fine...but it never shuts off.....ever?!
I would be careful using it. Chances are that it does not have enough freeon in it, and that will make it run all the time, it could catch on fire from the over heating of the motor.
Mar 21, 2012 | Danby DWC283BLS Wine Cooler
Danby DWC2121BLS Wine Cooler Logo
140 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
