Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Replace Harbor Breeze fan switch
Took apart fan and found out wires were off. There was a brown, purple,gray& black. on switch there is a L,1,2,3 which wire goes where?
  • 2 more comments
  • Robert Roth May 16, 2009
    I have a Harbor Breeze fan need to replace fan switch where do the purple, brown, and gray wire go. Two of the wires were off. on new switch trere is a l,1,2,3,which wire goes where.
    I have a Harbor Breeze fan i want to replace the fan switch. On the switch there are the the figures L,1,2,3. On fan there is a purple, gray, brown and black wire which wire goes to where.
    Yes it was helpful it gave a place to start and complete the job
  • Tim Harper
    Tim Harper Apr 23, 2017
    Thank you for the post, I was finally able to determine why my fan does not work on medium after replacing the broken switch with a new one. So it runs on high and low now until I replace the black transformer(?) box.
    President:
  • 987 Answers
There is a common wire, usually the black one. You can easily test this by using the continuity setting on a multi meter. The common wire will create a connected circuit to each of the other three wires (if the black wire doesn't work, it is possible one of the other wires is the common--you may have to try more than one).
Once you identify the common wire, this goes in the L hole on the switch. Before attaching the wire to the switch, however, you can now determine which of the remaining wires runs the low, medium, and high speeds of the fan. With the power on, simply touch the black wire to each of the other wires (ONE AT A TIME) to see which is low, medium and high. When you have determined this, attach high to hole 1, medium to hole 2, and low to hole 3.
Good luck, and of course, always be careful when working with live wires.
Posted on May 16, 2009
  • 483 Answers
You are going to have to trace the wiring inside the fan to make sure where what goes......
Usually.......
The White is neutral and goes to the white of the electrical box the fan is connected to. Black goes to the black in the same box. Green goes to the Ground.
The white goes all the way thru the fan and is connected internally to the motor and light kit neutral.
Black should go to the fan pull chain switch, the switch will have 3 outputs to the 3 speed fan motor.
The other color usually is for the fan light. It appears at the input on top in case you want the light on the fan to be controlled by a wall switch. Trace it by taking the light kit off, or if there is no light there is a round plate on the bottom of the fan. in some cases there is a light pull chain, in that case the blue will go to that switch, then to the light.
Here is one diagram I found.
http://www.do-it-yourself-help.com/wirin...
Good luck,
Fame
Please let me know about it.
    Genius:
  • 1,847 Answers
How do I connect the purple,brown,grey and black wires to a harbor breeze fan?
Try this; Purple - 3
Brown - 2
Gray - 1
Black - L
If this doesn't work you probably have the wrong switch. Just because they look the same on the outside doesn't mean they're the same on the inside!
Jun 09, 2015 | Dryers
I have a Hampton ceiling fan, its got a four wire fan switch, home depot gave me a Westinghouse 77286 with L, 1, 2, 3 wire points the fan has a black, purple,brown and gray wire. What goes were?
Just because the switch looks the same on the outside doesn't mean it's the same on the inside. You should have written the info down before removing the old switch. Anyway, try this;
Black - L Brown - 1 Purple - 2 gray - 3
Feb 10, 2015 | Hampton Bay Dryers
How to match unmatched colors in wiring for harbor breeze ceiling fan?
Sounds like you have the wrong part. Try to avoid store brand fans.
Aug 12, 2014 | Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Harbor breeze fan lamp..ligths stopped working
The light pull chain switch should be replaceable and available at Lowes or Home Depot .
Dec 25, 2017 | Cars & Trucks
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
6,723 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
