Question about Panasonic TH-50PH9UK 50 in. Plasma Television
Screen keeps turning green
Panasonic Th-50Ph9Uk My tv is 2 years old and the screen keeps turning green the picture is still there but everything is in different shades of green with a little red.
I had the same problem...turned it on and everything was a shade of sickly green, and no amount of colour adjust could get it back. I checked the forums and discovered that rather than the plasma tv, it could be a problem with the cable box. I checked other inputs, such as HDMI and my DVD hookup, and sure enough, the colour was fine (other than the residual tweaking I had done to repair it before). Problem solved, call the cable company (and save the expense of a repair or a new TV. Called the cable company and they suggested that I twist the connector cables between the box and the TV. This I did and it is as if it never had a problem in the first place.
All this to say, if you have this problem, try to check all the hardware connections first, before assuming that the TV is on the fritz.
I'm very relieved, that's for sure.
Posted on Jan 04, 2012
My Panasonic Plasma television started doing a green screen also. When it does it to me, is when I use the Last button or the Fav button. This is with Charter Communication. If I go back and forth, to various stations, then one station will turn green. So by trial and error, I found that when I clicked on a station, the screen would turn green. I had to push the Guide button, then the guide would come up, then push the Exit button, to get rid of the Guide, and then it would be on the station you wanted. If that does not work, then I have to just turn the TV off and turn it back on. It is rather annoying, however, as long as I can get rid of it, I can deal with it, instead of always turning the TV off. I don't know if this happens with all TV's or just Plasmas. If it does, I will not get another Plasma, if it happens with all TV's, maybe it is the remote, or the cable company. I just don't know.
Posted on Feb 18, 2011
Problem with plasma display on Panasonic TH-50PH9UK television
there is an x-buffer and a y-buffer. by disconnecting these and noticing if the picture changes you will be able to identify if it is on of these boards or if it is the screen itself. Youtube also has a lot of helpful videos. hope this helps
Jan 21, 2015 | Panasonic TH-50PH9UK 50 in. Plasma...
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Everything is red on my panasonic th-50ph9uk.
I have a Panasonic plasma 55 inch and the screen went green and pink is this fixable
Apr 07, 2013 | Panasonic TH-50PH9UK 50 in. Plasma...
I have a Panasonic TH-50PH9. The green ligth is on but I have nothing on the screen. When I push any botton on the remote, the green light blinks. No menu. nothing. Any ideas would be appreciated
Hi, First of all check your cable connections on the back make sure they are properly connected and in the right place.
Secondly make sure the settings in the menu are set to TV, DVD etc... what you want to watch.
Thirdly read you MANUAL for more info.
Jun 04, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
Green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Jul 10, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-50PH9UK 50 in. Plasma Television Logo
739 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
