Question about RCA F32650 32" TV
Keeps changing channels/volume by itself
The on/off button does not work, but the remote turns it off and on ok.
Then it just keeps changing channels and volumes.
It cannot be set to any channel with the remote or channel selection on the tv.
First problem ever.
The on/button has been split for a long time, but worked well up to this point.
I took the front switch unit to a repair man to have the switches replaced, or the whole cuicuit board.  He took one look, sprayed the whole board with WD40, and said try that!  When I put it back together, the on/off button worked, but everthing else did not.  I then took a can of automotive spray for wet wiring problems and soaked the whole cuicuit board and the switches  down and let it soak in. Then dabbed up the excess and put it back together.  Everything has worked perfectly now for two weeks!
Realtyguy.
Posted on Oct 27, 2007
  • 87 Answers
One or more of the front switches are likely leaky.  They are less than $3 apiece and I just change them all to save future problems.  You might be able to push all of the buttons on the front of the set a few times such as volume up and down and channel up and down and temporarly cure the problem but the switches will likely need to be changed.
Posted on Oct 16, 2007
Cant use menu
You may need a different remote. Is this a universal remote? Some of them have these common problems. Mine, for instance, doesn't use the OK button at all; instead, the Menu button counts as the OK button.
Try navigating the menu with the TV's volume / channel buttons (the ones on the TV itself, not on the remote). This usually works. Try that until you get a different remote.
Jan 29, 2018 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I have a Westinghouse 46" Class LED 1080p 120Hz HDTV,(2.14" ultra-slim) LD-4680 and the volume keeps going down by itself and it keeps trying to switch channels by itself. I have Comcast cable hooked
The most common possible cause is the buttons on the set, not the actual plastic buttons but the tiny micro switch (push switch that only should activate when the plastic button touches it)
these go bad and depending on which is bad things happen by themselves.
Lucky that it is not volume up, that is nasty.
The way to prove/disprove this is to get at those--usually they are on a tiny board and if individual ones unsolder the two pins for each (may be more to hold them in place) taking them out of the circuit, set will still work with the remote.
If your troubles are now gone just leave them disconnected and use the remote as only way today to replace is buy that board which will have the same poor quality parts as the old one.
For the tech minded they can be tested with a ohm meter--check resistance with meter set way up to over 20k scale---each has two pins(the switches) and should have ABSOLUTELY no resistance reading unless pressed. I have seen ones reading over 5k or 5,000 ohms and that is enough to act like they are being pressed.
Dec 05, 2012 | Televison & Video
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
My tv model #27F500T is changing stations all by it self
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
May 26, 2011 | Televison & Video
When you push a button on the remote, it either does nothing, or the channels start flipping all the way through from 2 to 120 and then start over. It is the same with the volume, if you hit it, it just...
If it doesnt happen when you change the channel or volume on the tv itself then i would recomend getting a new remote. You could probably get one on ebay. Most manufacture remotes will work on all of their tvs.
Nov 18, 2009 | Polaroid Televison & Video
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Keeps turning itself on
It's just magically switched on??? Do you have kids? ;-)
Jan 18, 2008 | Philips HTS3500S System
Channels
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
RCA F32650 32" TV Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
