Question about Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER
Router hookup I am trying to hookup my linksys route to my toshiba satellite. The settings on the computer for the network do not match the requirements of the network is the message I receive. Whats up? I went through the entire process only to get this message. Can you help?
  • Linksys Master
  • 4,338 Answers
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
Customize the Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
Toshiba Satellite C655-S5125 -
The Toshiba Satellite has a helpful program -- the Toshiba Wireless Manager -- to eliminate some of that frustration. Connecting to a wireless network using the built-in wireless usb wifi adapter on a Toshiba Satellite may require making some initial changes to the Satellite's settings. These changes can be made using the Toshiba Wireless Manager. As with all wireless networking, the settings of the laptop must match the settings of the network.
Mar 12, 2012 | Toshiba Satellite C655-S5125
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
Hi, I have brought a Wireless router (D-Link) and I am trying the connect my Toshiba notebook (L305D-S5892). In the available wireless netwroks it shows my network but it is unable to connect.The error...
There are a number of possible solutions for this problem. The best route may be calling customer support for Toshiba and/or the manufacturer of the Wireless router. I'm just brainstroming here, but when I tried to hook up my WII and XBOX wirelessly to the internet, I had to have a "G" connection. Further, you also don't metion the brand or model number of the router. My security setting also had to match there is WEP vs. 128 bit encryption, you have to make sure whatever the defult value is on the computer matches the network.
Usually there is a data plate somewhere on the laptop, probably underneath that will give you the model and serial number. There may be a customer support number nearby that you can call for futher assistence. I'm also assuming that you have "Windows" installed.
On my computer, I have the latest version 7 installed. If you're looking at the Desktop with no other applications running, press F1, then type in network connections, click search. On my computer, the answer came in at number 8, "Why Can't I connect to a network?". There are other possible answers such as "Setting Up a Wireless Network." Most people don't realize that there is built in help with the computer.
Dec 04, 2010 | Toshiba Computers & Internet
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Can't connect to public wireless "the settings saved on this computer for the network do not match the requirements of the network"
It sounds like you have a different wifi network with the same name as the public wireless network you are trying to access. I would open your wireless control panel (if you are using a 3rd party's product to manage your wifi, else use Windows' wifi manager) and delete any existing profiles with the same name as the public wireless network you are trying to connect to. Then try again. You may have to delete them in both the windows interface and a 3rd party interface before it will work.
Jun 18, 2010 | Toshiba Satellite A215-S4747 Notebook
THE settings on the computre dont match the requirments of the network
Are you talking about the wireless settings on the computer?
If yes have you reconfigured the settings on the router.
Have you changed the details for your network
If not try a complete power cycle.
Turn all the devices on your network off in the order they are connected wait for 30 seconds.
Hope it works!!!
Dec 07, 2009 | Linksys Wireless-G WRT54GS Router...
NO Wireless on Toshiba Satellite
attach your wireless router with modem then turn on the pc .. there is a pin whole at back of wireless router pin it in it would reset all of your setting . than go to internet explorer address bar type the IP 192.168.1.1 ususaly and the passward would be admin as well as user name .. then set the setting according to your requirment with out opposing IP ..than first turn of every thing computer modem router
then after 20 min first switch on the wireless router then modem and then your computer .. you will get connected through wireless router..
Jun 25, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Wireless connetion proublem
Im assuming that you have Windows Vista so go to:
>Start
>Control Panel
>Network and Sharing Center
>Manage Wireless Network
>Double Click on your Wireless Network or SSID
> Click on "Security" tab
>On "Security Type" click on down arrow to select "No Authentication (Open) "
>Click OK and it should connect !
Dec 08, 2008 | Toshiba Satellite A205-S4617 Notebook
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
