Question about JVC KS-F90 Cassette Player
JVC KS F90 Radio cassette loses all settings when switched off
I have just bought an MGB Roadster with this radio/cassette fitted.It also has a main switch that isolates the battery for obvious security reasons. The radio was not working but came to life when I replaced the fuse in the back of the unit! But when I switch the battery OFF I lose the settings on the radio and have to tune stations when I start up again. Is there an internal battery that should hold the settings for me or is there a rechargeable device I can add that would help? Everything else worked fine
Your radio probably needs a constant live to retain the radio settings. It may be that your radio has 2 live wires. 1 live that operates the radio coming from the ignition and 1 coming from a constant live that just gives enough power to retain the memory settings.
If you are going long periods of not using the MGB I would disconnect the battery to stop the it draining. If your battery goes completely flat it will damage the battery
Posted on May 31, 2009
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
How to get jvc fx732r to recognise mp3 input
The radio must be having a broken connection inside. replace the damaged parts.
Aug 10, 2009 | JVC KS-FX732R Cassette Player
JVC car radio looses configuration and stations when car is off
Sometimes positive and the switched positive are switched round on some cars. normally red and yellow but check first with multimeter
Aug 02, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
RESET 2 compact disc charger CH-X350 JVC.
I have no solution but the same problem and wish to solve it asap.
Anyone would you please help
If anyone has a JVC 12 cd's changer CH-X350 and also had the same problem (radio says when you wish to hear cd's : Reset 2), would you please tell.
thanks.
Mar 13, 2009 | JVC CH-X350RF 12 CD Changer
Setting clock
Try this (it is from the instructions for a similar model): The URL for this manual is: http://books.jvcservice.com/download/685823823/19755.pdf
Mar 30, 2007 | JVC KS-F110 Cassette Player
Car Audio & Video Logo
317 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
