Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
When we wash clothes they ar still wet at end of cycle. If I spin them a second time they are not as wet. We were not able to get the agitator off to get to where we thought the lint filter might be. We have checked the drain hose and it is not clogged. Any help would be appreciated.
  • kyer May 16, 2009
    it appears to spin the same as before. I ran a cycle with just water and water leaves tub, but it sounds like there is still water in the washer somewhere.
  • shinn8
    shinn8 May 11, 2010
    Does it seem to spin more slowly than normal
    Scholar:
  • 85 Answers
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 16, 2009
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes are still too wet at the end of wash and rinse cycle
Did anyone check the outlet tube to make sure it is clear of any debris and not tangled? I had this problem on another washer and it ended up being a crimped hose.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
597 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
