J Concepts Bar Codes 2.2 1/10 Truck Tire Gold 2 R/C Car & Truck Logo
Jimmy Butler Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 corvette has codes H53 ,H74 how to clead codes
My 1993 Corvette will not turn over with Key ignition codes H53 , H74
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Jconcepts Master 1,449 Answers
  • Posted on Dec 23, 2013
Daniel Mc Entee
Jconcepts Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275547
Points
3556
Need a scanner to clear the codes.
How to programe keyless remote 1992 corvette
https://northcoastkeyless.com/1993-chevrolet-corvette-keyless-entry-remote-fob-programming-instructions/
How could i reset the security lock on a 1999 chevy corvette
I can't find a reset for that year of Corvette. It is a Passlock system. So maybe the normal 30 minute procedure will work.
Perform the re-learning procedure
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON (vehicle will not start).
  3. Observe the SECURITY light, after approximately 11 minutes the light will turn OFF.
  4. Turn OFF the ignition, and wait 10 seconds.
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
If not, this site may help. http://diy-gm-security.com/
1993 corvette wipers will come on by the wiper switch but must be turned off by ignition switch
Since the ignition switch has to kill the power to the wipers. Replace the wiper switch. Carbon build up inside the switch is why it won't turn off. You could take the wiper switch apart and clean up the tabs with sandpaper. Beware of springs though..
1993 corvette was running great then going about 50 it just quit, cranks but won,t start
check your fuel pressure should be 35 to 42 with key on engine off,and about 5 to 7 more with engine running and vacuum line off the regulator,also check your fuel regulator with vacuum off it should be dry if it is wet with gas it is bad
72 corvette won't start with but will crossing the starter with screwdriver
sounds like the wire between the ignition and starter is broken or fusible link is blown should be a big fat purple wire would start there
4helpful
My 1993 corvette wont start
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
Need to know what te replacement battery is for a 1993 corvette key fob.
Take out the old battery from your key fob and it should have the markings on the old battery.
Top Jconcepts Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Jconcepts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
