Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
TUMLE DRYER NOT WORKING
For no reason at all the tumble dryer function just stopped working - can wash just can't dry. Any ideas?
  • Hotpoint Master
  • 19,396 Answers
Test heating element, thermal fuse and vent system, if none of them is faulty, then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 16, 2009
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
The tumble dryer function on my Hoover Performa 1100 WA 110 isnt heating up
The machine has a overheating protection that is blown. But you can reset it. Take if the top cover. You should ser a small black round temp sensor with two wires. And a red button in the middle. Push the red button. It should work. If not it could be many reasons for this
Nov 11, 2013 | Washing Machines
I have a TB condensing tumble dryer, model TM310W, which has always worked well, but lately, although the clothes are drying, there doesn't seem to be much water going into the reservoir. I can't find it...
The first decision you must make when buying a tumble dryer is whether to buy a vented or a condenser dryer. As you'd expect, there are pros and cons for both. This page helps you understand all of the differences, including the reliability and repair implications. Condensor tumble dryers are becoming more popular but vented tumble dryers still have some advantages and the convenience of not needing a venting hose (as always) requires some compromises.
Until I can put together my own reviews the best Tumble Dryer reviews available online are by Which?
Due to their resources and independence, Which? usually have the latest reviews and collect the opinions and experiences of thousands of members - Which? tumble dryer reviews (Plenty of free information but will need to be a subscriber (take advantage of the 1 month trial offer to get the full benefit)
Vented tumble dryers are cheaper than condenser dryers, they are also simpler, more reliable and more economical to run. According to Which? "on average, vented tumble dryers use about a fifth less energy than condenser dryers to dry a full load of cottons."
So why bother with a condenser tumble dryer? Well condenser tumble dryers are a convenience product but they do offer a solution to a genuine problem for some where venting the dryer outside is difficult or even impossible.
My advice would be that if your tumble dryer can be sited somewhere that allows you to correctly vent it outside, either through a wall or through a window, then a vented dryer is probably best. If this would be particularly awkward, then buy a good quality condenser dryer, which should condense the steam into water.
Modern washing machines now have a far superior spin speed, and, of the ones we recommend, the cheaper model has a 1200 spin speed, the other a 1400 spin speed... so your washing will be fairly reasonable (some items could be about ready to iron) and this, in turn, could affect your other choices.
Could you get away with just airers and a washing line? Or have you considered a dehumidifier?
A Spin Dryer... will work efficiently, and is cheap. The main advantage to it is that it is only the size of a large pedal bin, so it can be stored under the worktop in a small amount of space.
A Tumble Dryer... much more expensive... for a decent quality item you need to pay a quite steep price. They do a good job, but are another full size kitchen appliance to find room for.
A Washer/Dryer... instead of a washing machine... disadvantages, if it goes wrong then you have no back up in either the washing or drying department... and of course being a more complicated piece of machinery, it IS more likely to break down! The only advantage is that it will be a space saving item.]
please comment on these on how helpful.
Dec 21, 2010 | Electrolux Dryers
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
No heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Nov 26, 2008 | Dryers
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
179 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
