Question about Logitech Attack 3 Joystick
Logitech attack 3- Z axis- throttle "default" starint value
I got this joy, and the throttle starts as default on mid level, even if its full down or up on the joy itself. it casues problems, as in test once i switch a bit on throttle on the joy, its working fine, but as soon as i exit, go to other window or so, it resets itself back to middle. newest driver installed, everything else works smooth. as long as this is up, it is unusable, as it resets itself like every 1 second.
Os: XP x64 sp2
solutions welcomed.
Thanks,
Johnny
  • kis_janos_pr May 18, 2009
    yes. not helped, even tried with own logitech gaming software, no luck there neither
  • 69 Answers
Have you calibrated it?...."start" "control panel" IN **CLASSIC VIEW** click the GAME CONTROLLERS and then propertys...it should say your device and after highlighting you stick a window will pop up hit the SETTINGS tap and hit CALIBRATE do what it tells you and try using it again....
Posted on May 18, 2009
  • Frank Allik
    Frank Allik May 18, 2009
    not to say anything insulting....but after setting the new commands are you hitting the "SAVE " button ? before playing the game....also try default...what game(s) the issue with as well?
I am playing Flight Simulator X Gold Edition. On my Logitech Attack 3 joystick, what is the throttle control level number? Please help!
I have the same stick, the throttles are actioned by the little levers in front of you at the bottom of the stick, I dont quite understand what you mean by level number...
all you have to do is configure them in the configuration panel of the flight simulator, I use same simulator for practice.
Aug 19, 2011 | Logitech Attack 3 Joystick
Logitech attack 3 joy stick does not work in my xp
The joystick should come with a USB cable to connect to the computer. Once you have connected the joystick to the computer go to your control panel and click on the Printers and Other Hardware. Next you can click on Game Controllers, next you click on add and click on how many buttons there on the joystick (Example: 4 buttons joystick w/throttle). Once you have completed these steps you want to click on the controller then click on properties to give your joytick a test run before you play a game you have.
I hope this information can help you and hope you enjoy your games that you use with your joystick.
Dec 31, 2010 | Logitech Attack 3 Joystick
Bought attack 3 joy stick -won't do anything
Try unpluging stick from pc,And changing port where its plugged into.
Next try unpluging stick and reboot pc,once pc is started,plug joystick back in.
Thanks and good luck
Jan 12, 2010 | Logitech Attack 3 Joystick
I want to know will a Logitech Attack 3 Joystick work on need for speed underground 2 or can you even use joysticks fos racing games
ya the joystick will work you can use it because am also having the same am using it , its perfect but you have change control options in the game to joystick control and also if you want you can the options as you like, but this kind of joy is mainly used for flight running games but it also works for all joypad control games too.
Oct 22, 2009 | Logitech Attack 3 Joystick
How many axis and buttons on the Logitech Attack 3?
It is a 2 axis joystick with 11 programmable buttons.
Please rate me if you are satisfied with my answer.
Aug 20, 2009 | Logitech Attack 3 Joystick
Problems with vista
it is better to use windows xp!!! if you are using vista find the name of that joystick!! does your joystick have cd driver?just install the driver!!!
Jun 30, 2009 | Logitech Attack 3 Joystick
Need profile for logitech attack 3 joy stick for cod4
You should use logitech wingman profile software, then set up key commands to joystick and then force profile.
Its better than try to mod ini files!
Download it from logitech.
Mar 27, 2009 | Logitech Attack 3 Joystick
LOGITECH ATTACK 3 JOYSTICK.
OK I had the same problem..What u have to do when u set up the controls is leave ur throttle axis (little sliding doohickey at the bottom of ur joystick) in the middle position.That should do the trick..
Cheers Kevin
Jun 07, 2008 | Logitech Attack 3 Joystick
Directions for the joystick buttons on the attack 3
First make sure that the game supports joysticks. Most shoot em up games do not support joysticks, just gamepads and / or mouse and keyboard...
Apr 13, 2008 | Logitech Attack 3 Joystick
X AXIS INSTABILITY
Is this an issue only with this game or other games as well?
Here are some articles from the logitech website that may be of some help...
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=289
and
std_adp.php?p_faqid=27
Dec 22, 2007 | Logitech Attack 3 Joystick
Logitech Attack 3 Joystick Logo
1,106 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
