Question about Sony Ericsson W380i Cellular Phone
Disassemble of plug of battery charger
Hello, i've a w380i cellphone, while trying to disconect the battery charger the "plug" disassembled, it seems easy to reasessemble it. But, i don't know in which slot of the plug goes the red end (i guess is the positive) and in which goes the black one (i guess in the negative). I know they go towards one side, but i don't remember, starting by one side, how many slots have to be left empty, and how many slots goes empty between the red and black wires' ends
Could you help me?
  • 271 Answers
SOURCE: k800i
The memory slot is covered with a labeled ruber...pullout that ruber with the finger nail...there you have the slot inside...
<PLEASE RATE ME AS FIXYA>for my help......................
Posted on Jul 31, 2008
  • 143 Answers
SOURCE: i work up 1 mornin and my phonw won't turn on
some problem with the battery connectivity. try to get it clean serviced by a local person it may cost you some bucks
Posted on Aug 28, 2009
SOURCE: disassemble samsung sgh-d820 cellphone
i didnt solve my problem cause i had no help
Posted on Feb 05, 2010
  • 308 Answers
SOURCE: My Sony Ericsson Walman Phone w380a refuses to
carefully scrape the contacts on the fastport on the side of the phone so it can make good connection
Posted on May 20, 2010
  • 1417 Answers
SOURCE: how do I disassemble the screen side of the Sony TM506 Phone
there two ways which you can use to revise the screen problem of your phone
1).click on the menu button of your phone stroll down to setting click on it then stroll to display settings click on it then click on then stroll to screen and click on OFF or able
Secondly you will have to hold to your phone ash button for few seconds.
Thank you and thanks for using fixya.
Posted on May 30, 2010
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
I have a Acer Aspire 5050-3371 Notebook. Before, I had a problem with it's battery and plug, so I disassembled it and found my DC input battery plug broken. I replaced the DC converter, and assembled...
Sometimes when the charger connector breaks, it shorts out the charging module on the motherboard, blowing it. It can also blow the external power supply.
If you can find someone else with a similar power supply, try using it. If that doesn't work, you've got bigger issues.
Jun 25, 2011 | Acer Aspire 5050-3371 Notebook
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement:
May 11, 2011 | Garmin nuvi 255W GPS Receiver
My laptop charger stops working when I plug it in to the port of the laptop. The laptop won't turn on
Try taking out the laptop battery and then plugging in your adapter / charger to the laptop.
If your machine still does not come on, then you probably have a blown capacitor in your charger.
If you are handy with a soldering iron then just disassemble the charger body and replace any suspect components.
Otherwise just order a new one.
Good luck.
Apr 17, 2011 | Computers & Internet
The tip of my AC charger broke off on the contact post of my samsung sph-a620. A new charger cannot make contact for recharging purposes. I cannot see how to disassemble the phone to access that electrical...
To disassemble the phone, you need to get he appropriate screwdrivers and follow the processes below;
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers and unscrew the aerial.
  2. Remove the screws,
  3. Next remove the 2 rubber stoppers & screws above the main screen,
  4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  5. Unclip the ribbon,
  6. After removing the ribbon cable, carefully lift the metal part. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with just the screen and the keypad rack.
  7. On the circuit board, you'll see the charging port and the broken charger that is in it.
  8. Try to pick it out with a pincher, and if you cannot, then you have to replace the charging port.
  9. Disconnect the charging port and replace it with a new one.
  10. Reverse the process to reassemble the phone back together.
  11. Take care.
Jun 22, 2010 | Samsung SPH-a620/VGA1000
Deadphone after recharging, message says
try use a good battery. if it does not work, try check on the connecting pins on the battery connector of your cellphone. if still a problem, try disassemble the cellphone to check the battery interface on your cellphone, clean both connector and the interface of your cellphone... if still a problem, best to repair it to a nearest cellphone technician...
Jun 01, 2010 | Motorola Mobility RAZR V3
I have a sony ericcson W380i and it now will only light up when I switch on and then nothing else happens - so the battery is OK but no function is working. It was fine last night but not when I went to...
That means that the phone is not comleting the initial phone test, and not booting.
Remove also memory card.
Check the connector at the base of the phone, where you plug in the charger. Ensure that it is clean , and that there is nothing that can make contact in there (eg. oxide). If you need to clean the connector, remove the battery first.
Try holding the phone start button on top for about ten seconds.
Go to a shop and ask them to test a spare battery, or if you have a spare battery, test it. A shorted battery can cause the phone not starting.
If it is none of the above, then it is a faulty board. Also a short inside the phone or a faulty switch can cause the phone not starting. In that case the phone must be disassembled and repaired.
Oct 23, 2009 | Ericsson Lands Phones
Sony Ericsson W380i Cellular Phone Logo
261 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
