Question about Canon EOS 1Ds Mark III Digital SLR Camera Digital Camera
Brown spot inside viewfinder
Hi, i have a brown spot inside the viewfinder ive tried cleaning it but it still there any suggestions on how to get rid please it doesent affect the photograph also the plastic deffuser/glass inside the top of camera is scratch can this be replaced. many thanks chris
old marine
  • 2005 Answers
SOURCE: A black line on the top and bottom
In your Recording Menu, check that the Disp. Overlay is turned Off. The lines are showing the portion of your image that will be cropped if you print a 4 x 6 photo (3:2 Guide).
Posted on May 06, 2008
  • 153 Answers
SOURCE: scratch on camera's LDC screen
do you mean the plastic cover has become scratched or the screen itself is malfunctioning?
If the screen is malfunctioning return it.
If you have scratched the screens protective cover there is a great product called "displex" (i buy it off ebay) buy it with the special cloth, Its a very fine abrasive that will polish out scratches and blemishes.
It takes some time rubbing the screen to work but it usually comes up a treat (dont press too hard) Iv recovered some absolutly trashed screen covers with it. Once its sorted use a screen protector to keep it good
Best of luck
Posted on Jun 10, 2008
davesoucy
  • 148 Answers
SOURCE: Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Posted on Aug 04, 2009
  • 11967 Answers
SOURCE: spots showing on photo's
Google the words...digital camera sensor cleaning. You will find complete instructions and where you can buy the supplies.
Posted on Sep 28, 2009
SOURCE: I have a Canon PowerShot A1100IS camera. A problem
Received an explanation from Canon.
Posted on Dec 10, 2009
When using any lens, the view through the viewfinder has small spots like a liquid was sprayed on a optical component. What is this and how can I fix it?
It could be on the mirror, the underside of the focusing screen, or the back of the viewfinder. All three can be inspected visually.
The back of the viewfinder can be cleaned with any window cleaner. Don't spray any directly onto the camera, but rather onto a clean microfiber cloth and then wipe the viewfinder clean.
The mirror and the focusing screen are more delicate. First try a handheld blower (NOT canned compressed air). If that doesn't do it, try a camel-hair brush. Only then resort to wiping it with a clean dry microfiber cloth. Use common sense, and avoid scratching the mirror/focusing screen.
If it's on the inside, the camera will need professional cleaning.
Sep 28, 2012 | Nikon D80 Digital Camera with 18-135mm...
The viewfinder on my Panasonic PV-DV200 needs to be cleaned. I have the instruction manual but I cannot get it to turn the 1/8 turn recommended to remove
Hi, My PV-DV200's viewfinder needed cleaned too. Try, try and try again. The entire viewfinder assembly will turn, but if it's never been removed before, it will be on extremely tight. My viewfinder has a small notch at about 1 'o' clock on top. That notch needs to be turned to about 11 'o' clock. Once there, the viewfinder slips off easily. It will come off much easier from then on.
However, simply cleaning the removed viewfinder may not be enough. You may also need to remove the two small screws on the underside of the piece that's still attached to the camera in order to get inside there and clean that too. I removed the small rectangular glass and cleaned that and behind there as well. I used a Rayban cloth (needs to be lint-free) and some Plexus, along with a dull pencil in order to get everything cleaned all along the sides of each lens.
Just double check and make sure all parts of the viewfinder are clean by slipping everything back into place prior to screwing it all back on. This will save you some time because you will probably not get everything cleaned on your first attempt.
Hope this helps!
Nov 16, 2011 | Panasonic PV-DV200 Mini DV Digital...
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
Spots showing on photo's
Try using a sensor cleaning kit. It sound if you have dust on your sensor. The cleaning kit most probably will solve your problem.
Cheers
Sep 28, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Spot on my lense and it shows up on my photos.
I doubt it would be a good idea to try to get in there and get rid of the spot yourself.
If it does not affect your photos significantly then leave it be or if you feel you must, have a a professional clean it. ($$$$). Weigh the cost vs. leaving it alone.
Jun 20, 2009 | Kodak EasyShare Z650 Digital Camera
Minolta X-370 Spot driving me nuts!
If its inside the viewfinder, then you'll really need to take it in for a repair, but bear in mind, that will require disassembly and that will likely run you $75-$100, which is more than a used X370 goes for on eBay.
One thing I would check is the underside of the focussing screen as maybe it is on there. Remove the lens and then look thru the viewfinder. If you still see the spot, then its in the body and not in the lens.
Look inside at the underside of the prism - thats where the focussing screen is. Do not touch the screen with any cleaning fluid or your finger. instead, grab something fairly stiff but pliable, like the straw on the edge of a dust blower. and gently rub the general area on the screen where the spot might be. Then blow the area with air to clean it all up. Look thru the viewfinder again and see if that got it.
Its pretty rare for dust to get inside the viewfinders unless they had previously been open for a repair, so theres a good chance its stuck to the focussing screen. Don't touch it with solution or your finger though as the screen can be damaged easily.
Dec 29, 2008 | Minolta X-370S 35mm SLR Camera
Brown sticky spots
sounds like you have an oil leak from the motor/pump assembly. this should be covered under warranty by the mfg. have a technician replace the sump assembly.
Aug 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Canon EOS 1Ds Mark III Digital SLR Camera  Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
