Question about Garden
Gasoline fills the crankcase
On the Troy Bilt bronco lawn tractor, gasoline fills the crankcase when its stored for a short period of time..........is it the carb?
  • redmolly13 May 16, 2009
    That sounds logical to me...what specialized tools would I need?
  • 376 Answers
Yes it is. The float needle and seat are leaking and need to be replaced. I'm assuming it it a Briggs and Stratton engine. Just replacing the rubber tipped needle usually will not stop the leakage, the pressed-in brass seat also needs to be replaced and pressure tested. This would really need to be done by a shop. Not a hard job, just requires specialized tools to remove and install seat and pressure test..........
Posted on May 16, 2009
  • Dwain Pippen May 16, 2009
    I was afraid you'd ask that. lol. What I use, I made, except for the pressure tester and they cost retail around $95 from 'Stens' #705-020 or from Rotary Parts #8338. Both are over priced, imho. Unless you know someone that can get you dealers price on one of those, doing it yourself really wouldn't be economical. If you still want to try it yourself, let me know and I'll try to describe what I use or try to figure out how to post a picture, if that's possible on here. Dwain
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
Gasoline / oil leaking from crankcase
hello p, the leak is coming from the rear crankcase cover which is located in front of carb, the screws may have loosened up or the pencil lead thin gasket has a crack, remove the air filter cover and carb,the four screws holding the cover on and you will see the gasket,not much of one but it is there,as far as i know i have never had a front seal leak,oh when the carb leaks it seems like the crankcase is leaking,so check it good,hope this helps,
Jan 17, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower bronco belt broke HELP!
hi try this site its called pats small engines
Apr 13, 2009 | Garden
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
