Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
Hardwired pc cannot recognize network (local access only)
I re-setup my netgear wndr3300 router after re-installing windows. my laptop connects great wirelessly, but my PC only shows local access and an unknown network.
  • 854 Answers
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
Note: Name (11N SSID) is for wireless N computers running at 5GHz and the Name (11G SSID) is for wireless G computers running 2.4GHz. Kindly make sure that (11N SSID) and (11G SSID) names are different.
c. Set the mode to Up to 270Mbps at 5GHz & 54Mbps at 2.4GHz.
d. Set the 11N Channel to 48 / 5.240GHz and 11G channel to 1 / 2.412GHz.
e. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
6. Connect wireless computer to the router.
Note: If your wireless computer supports 5GHz and 2.4GHz frequency you will see two wireless networks which are 11N and 11G SSID. However, if your wireless computer only support 2.4GHz frequency you will only see one wireless network which is 11G SSID.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet with the ideal speed you have from your ISP.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Who is your internet service provider? Is it Cable or DSL connection?
2. How many wired and wireless computers are connected to the router?
Posted on May 28, 2009
What does the LAN do on the modem
There are two halves to a router. The internet (WAN) side a local network (LAN) side.
The term WAN means Wide Area Network and generally refers to the internet.
The term LAN means Local Area Network. That would be for the computers that are in your office or home.
The LAN connects your computer to your printers or to other computers.
I hope that answers your question!
Jul 02, 2014 | NetGear WNDR3300 - RangeMax Dual Band...
I recently installed a netgear wndr3300 router at my home. I went through the setup process with no problem, and everything checked out ok. But when i clicked finished, a screen popped up saying the ip...
If this is the case, the setup wizard detected an IP conflict between the router and the modem. It means that the modems IP address is in the same range as you router so it has to be changed. If the IP address of your router was changed to 10.0.0.1 , you should be able to connect to the internet. Try accessing the routers setup page by opening a browser and type 10.0.0.1 at the address bar. It will ask you for a username or password. Type admin for the username and password for password (this is the default settings). If it does not work try to remember if you already have changed the username or password. Once you are in, enable the mac clone option. Check if it works.
Apr 18, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
WNDR3300, i do not remember the password i used to get wireless access to the router. how do i reset the password?
You will have to reset the password. You can download a user guide from http://kb.netgear.com/app/
Cable from your laptop to the back of the router (one of the outputs).
Open a browser window and type http://www.routerlogin.net
log in and follow the user manual instructions to set up your network and network password.
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have a netgear rangemax due wireless n router. I had a friend, who is good with computers, set it up for me last april. he set it up through my desktop, which is connected directly to my broadband,...
These are some reasons why your new Hp laptop can't connect through your Netgear Router is because your Router has a security that used a password to connect to your router or the ip address of your desktop and Dell laptop is already setup to the router to work with internet.
You can learn how to setup your router easily.
Smart Wizard:
http://syndicate.sellpoint.net/Netgear__Inc_/90983/16285-8W6DBC-28-player-T1_MP/MPPlayer/MPPlayer.html?Master=Self&PlayerTitle=&ShoppingCart=http%3A%2F%2Fsyndicate.sellpoint.net%2FNetgear__Inc_%2F90983%2F__buybutton__.html&LVerify=Syn-WMP2YD-90987&Width=536&Height=525&ParentUrl=http%3A%2F%2Fwww.netgear.com%2FProducts%2FRoutersandGateways%2FWirelessNRoutersandGateways%2FWNDR3300.aspx
Netgear Data Sheet:
http://www.netgear.com/upload/product/wndr3300/wndr3300_ds_25sep09.pdf
Here's the instruction how to access your Netgear Router (to change the settings and to allow your new Hp laptop to connect to the internet)
http://www.ultimateone.co.uk/article/netgearrouteripaddress
I suggest to use a password security, for easy connection of your computers
Jan 18, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I have upgraded to windows 7 and my internet is slow. I have the instal disc but when i try to re-instal the router it says that The network adapter in this computer is not responding. You must use the...
Are you trying to install the router ?
Check the status of the network connection.
If the local area connection is disabled then enable it.
Click start . go to control panel. go to network and internet. go to network and sharing center. You will see view network connection. Under that check for the Local area connection.
You can set up the router manually also without the CD.
Click Here for more info about router set up.
Nov 29, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear WNDR3300 RangeMax Xbox Live Failure
Follow the below steps to configure settings on the router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Scan for the wireless network on the XBOX and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 27, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Acer one and netgear WNDR3300 router
Make certain tha you have your firewall setting allowing the wireless card to connect. When you type your password in make certain that your caps lock is not turn on. Finally if your computer can only run wireless B, you have to tell your to broad wireless B and G, or do a protection mode, where older wireless device will connect.
Oct 10, 2009 | Computers & Internet
I can't connect to my wireless netgear wndr3300 to XP
It seems that the wireless adapter on XP does not support WPA2 Security. Please enable WPA-PSK on the router and check if you are able to connect to the wireless network on the XP computer.
ENABLE WPA SECURITY
Configure XP computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 03, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NETGEAR rangemax router
make sure you have enable wireless in router setup page
if you are using USB key remove cable and see if you can see your network .... if not remove your usbkey and see if your laptop Recognize the disconnect ... need additionla info on yout setup if this does not work
good luck
Jun 07, 2009 | Dell Wireless 2350 Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
709 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
