Question about RIM BlackBerry Pearl 8100
I couln't open any of the applications by clicking th trackball
Mine phone was working well but suddenly one day i meet with a problem nw i couldn't open any of the applications by pressing the trackball now every time i have to press the enter key if i wanna open any of the applications. could u help me to come out of this trouble i'll be thankful to u.
  • 78 Answers
Press both the soft keys to hard reset while switching it on
Posted on May 17, 2009
How do i use my bluetooth to transfer pictures from lg290c to hp laptop
Firstly switch on th bluetooth on both th devices..
nw pair the bluetooth of th phone wth ur laptop.. Nw transfer files to ur laptop frm ur phne.. :D
Nov 22, 2011 | Cell Phones
Trackball doesn´t move to the right
back your phone up and reflash the software ...you can wipe the s/ware using jl commander
Mar 08, 2010 | RIM BlackBerry Curve 8310 Smartphone
On my blackberry 8310 the keyboard and the trackball are locked up. Can this be fixed?
the trackball can get dust and particals in the runners, if you have a star driver you can undo the phone, gently pop it apart then pop the silver plate connectors for the keypad, screen and trackball there should be a wire coming from the mouthpiece to the top right gently disconnect the top this will allow you to open the rear of the keypad and roller ball, where the rollerball meets the motherboard gently clean this with a cotton bud, do the same with where the keys meet the white sensors
Pop every thing back reverse order and the rollerball should work, if not it will need to be tested by an engineer as it will be a connection problem, hope this helps
Feb 15, 2010 | RIM BlackBerry Curve 8310 Smartphone
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I cannot click using my trackball (AT&T Blackberry Curve 8310).I can scroll up and down but when i go to click on any applications, a menu comes up just as if the menu button to the left of the...
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 19, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My blackberry world edition's trackball suddenly started selecting things as if I pressed the trackball even though I haven't. If I open email it clicks the links in it as I scroll past and reply pops up...
You might have one of three things wrong with your blackberry 1. something is stuck down there like a peice of plastic causing the button to seem like its being pressed all the time or 2. there could be water damage in there thats if you bring your phone into the bathroom with you while taking showers humidity is like cancer to phones it might not show up right away but it can happen 3. someone might of pushed the trackball so hard that it dented the button in this case i would take it in to get repaired. If it is one of the other two it should be an easy fix you can check for either one of these problems underneath the trackball by removing the ring that is around the trackball you can do this by carefully prying around it off then you should be able to drop the trackball itself right out of the phone aswell as any thing stuck in there or if there is water damage or any water down there I suggest you turn the phone off as soon as possible to prevent any further damage then I would just leave the phone in a nice dry place to get rid of the water then the trackball should work again same thing goes for removing anything that might be stuck down there after that is all done with you should be able to reassemble it remember the ring around the trackball only goes in one way so do force it or you risk breaking it.
Cheers,
Kyle
Jul 05, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The centre scroll button doesn't 'click'
As you use the trackball on your Blackberry, dirt and oils on your fingers get into the trackball assembly.
You might get some 'traction' on your track ball if you lightly dip a cotton swab in some rubbing alcohol. Swab the trackball, then do a quarter turn, continue until you cover the whole trackball in each direction.
If you get no improvement, then its another defective trackball, and you'll have to return it where you got it; most companies warranty phones 90 days from the date it was replaced.
Jun 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
with nokia you can update the software in the phone. you get the program off nokia. nokia suite or nokia software installer.
Jun 01, 2009 | RIM BlackBerry Pearl 8100
BLACKBERRY TRACKBALL/KEYBOARD ISSUES
you need to take the phone to a mobile service center and have the trackball service the pins could have alot of dust and dirt on them.
Dec 05, 2008 | Cell Phones
RIM BlackBerry  Pearl  8100 Logo
120 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
