Question about Garmin GPSMAP 235 Sounder GPS Receiver
Hooked up this spring but can't find satellites. Nothing has changed
Problem with my garmin 235 sounder is when I hooked it up after a winters layoff the unit can't find itself. It keeps searching for satellites but can't hook onto even one. Could it be my antenna or is there a internal battery that needs replacement Thank you CJ
Thanks for the comeback.
Problem was my antenna wire. Somehow the wire wore through where it went through the hard top. Probably due the the high winds we had this winter which caused the cover to rub and pull against it.
Thank you
CJ
Posted on May 17, 2009
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
My unit back light is not working. the chart is displayed but can only be seen if you hold it to your face.
Backlights are part of the LCD display and consist of LED's. You may have to replace the entire LCD display or find another display that is cracked but has a working backlight. In most cases, you can swap backlights. There may be some soldering involved.
May 28, 2013 | Garmin GPSMAP 235 Sounder GPS Receiver
My gps172c fails to receive any sats...same problem last year,boat laid up over winter and in spring when set switched on no sats picked up .Garmin sent me software update and problem solved. Unfortunately...
Similar problem with a Garmin finding current position taking very long time every spring after boat being laid up in winter.
See page 4 and 5 to speed up the process.
When Garmin does a power-up the current version is revealed during the boot. This will ID the update!
The at home(current position) delay maybe due to satellite re-position during the winter and has been the only problem. Once acquired have little or no problem rest of season.
See page 6 on link manual where you can observe the satellite acquisition. During the initial acquisition process it seems to start over many times and eventually locks them in one at a time!
http://static.garmin.com/pumac/GPSMAP172C_OwnersManual.pdf
Hope this helps?
Jul 04, 2017 | GPS
Garmin 178c won't find satellites
It would appear that your Garmin has no clue as to where it is on the planet. I think a trip to the owner's manual:
http://www8.garmin.com/manuals/GPSMAP178CSounder_OwnersManual.pdf
might be your best bet to help initialize your unit. The info on how to graphically initialize your Garmin can be found on page 5.
Hope this is helpful.
Good Luck!
May 04, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Need G Charts for south florida
You will need to get G Charts directly from Garmin.
Aug 13, 2009 | Garmin GPSMAP 235 Sounder GPS Receiver
After siting for winter, just bought new battery. engine is turning over but wont start. Radio, vhf. depth sounder, horn, etc is not working. checked all the fuses and there ok .any suggestions. I have a...
If you put a new battery in the boat then look around the battery and make 100% sure that you hooked up ALL of the accessory wires to both NEG and POS posts. Sounds dumb but I have come accross it multiple times. As for the engine, if it turns over but will not start then I am about 80% sure that you need to have your carbs cleaned. Fuel sits in the bowl of the carb, then after about 30 days starts to varnish, after varnish it starts to look like mollasses. Then spring comes around and you squeeze the fuel bulb and crank it over forcing that old **** into your idle jets. That is why it is really a good idea to have your carbs fogged before you store your boat for the winter.
Jul 18, 2009 | Boating
Need replacement G-Chart Cartridge
Hey I too have a Garmin 235S GPSMAP, I am looking for the G-Charts, Have you found any source yet ? reach me at jim.rosemary@yahoo.com
Jim
Oct 16, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin 168 Sounder LCD screen display errors
I had the same problem and contacted Garmin. This is being caused by a software issue that started when the government updated the software in their WAAS satellites. The Garmin website will give you instructions on how to correct this but I have listed them below:
Power on unit
Press enter to get past the I Agree screen
Now you should be on the satellite page, press the menu button one time
Highlight WAAS off and press enter
By doing this, the unit should not shut down.
I followed these instructions and my 168 Sounder is working fine.
Jul 31, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
GPSMAP 235 Sounder
Some 235s had a problem with the contrast setting. When the contrast is set to full the screen turns black.
When you turn on the GPS and the screen goes black, try tapping the left arrow on the track pad a few times. You should see the screen start to lighten. If that doesn't work, tap the power key and try tapping the left arrow a few times.
May 17, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin GPSMAP 235 Sounder GPS Receiver Logo
246 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
