Question about Samsung NC10-14ROBL Notebook
'On' switch lights up, laptop doesn't start up
Samsung NP NC 10 notebook, when I press the 'on' button, it lights up as normal, but nothing else happens, no screen, no flickering of drive light, nothing. Have removed battery for some time but on replacing it, same symptoms, a dead notebook. Any ideas welcome.
Samsung NP-NC 110p restarting after powering
Hi eric, please press F8 continuously after powering it on then select Last Good Known configuration from the list
Apr 03, 2014 | Samsung Computers & Internet
My samsung np-n150 notebook will not boot up past the microsoft corp loading screen in either safe mode or normal mode. how do i fix it?
need more info.
have any recent changes been made and if so, what?
can you get to the start up menu by pressing f8 before you get to load screen?
do you get any error messages?
Jan 07, 2013 | Samsung N150 Series Netbook
Lights on nobodys home
Unplug it, remove battery, hold power button 10 full seconds, reinstall battery, plug in and turn on. It should work fine now. If not, memory stick is likely bad.
Jun 09, 2012 | Samsung Np-r530 Np-r530-ja05us R530 Laptop...
Samsung notebook screen turned sideways
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
May 11, 2012 | Samsung NP-NC10-WAS1US Notebook
Samsung r 700 laptop where is the wireless switch
Hi Welcome to FixYa!
For your laptop, it does not have a physical switch for the Wireless switch. But dont worry, you can enable the wireless adapter on your computer by pressing the key combination of "Fn+ down arrow key."
once you have pressed it correctly, the Wireless LED will light up.
You could refer to the user guide on this link: http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=NP-R700&prd_ia_sub_class_cd=P
hope this could help you.
Jun 30, 2011 | Gateway 7330GZ Notebook
HP Pavillon dv62030ez No more start up. Fan and lights get power for a second, then nothing. Think thr BGA doesn't fit any more, due to overheating.
Hi
This may be a problem with the bios. Try to reset the bios. follow the below procedure
1. remove the main battery
2. remove any USB cables etc., if connected
3. hold the power button for 15 secs.
4. reconnect the power adapter (Do not install the battery yet)
Later if the system starts well then shut down the Laptop and install back the battery and connect the charger and start the Laptop again
If the above will not solve the problem then follow the next step
1. Remove the power adapter and the battery
2. Open the back side cover where the Memory is installed.
3. remove the BIOS battery
4. leave the laptop for a while may be 10 mins.
5. Now connect the BIOS battery back
6. System will automatically start do not press the power button
7. set the date and time
8. Shut down the Laptop
9. Start normally back on.
DO RATE MY SOLUTION
Saleem
Jun 30, 2011 | HP Pavilion dv6000z Notebook
How to locate the @ button on the samsung NC10 the shift and @ button does not bring up the character
Depending on the lap top... try pressing the function key, then press shift and the number 2. Also, check in the control panel to make sure you are using the correct language (try pressing - Alt+Shift at the same time to switch the lang).
Jul 08, 2009 | Samsung NC10-14GW Notebook
Acer aspire 5610
remove power supply then remove battery.
then connect to power supply and try to boot, if no luck then remove power supply and press and hold power button on laptop atleast 10 seconds then in the same postion connect the power supply.
if still no luck then you should take a tour to service centre.
For any more question just ask me.
Thanks
Iqbal
Jun 29, 2008 | Acer Aspire 5610-4648 Notebook
Samsung NC10-14ROBL Notebook Logo
290 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
