I have a Toshiba SD-26VB Combi with remote. The best I can get is a picture rewind which takes so long when rewinding the whole length of tape. Is there a combination of keys or a set situation that will make the VCR rewind fast with no picture showing as other VCRs do? I have lost the user manual.
  • Michael Wightman May 16, 2009
    Thankyou yes - very helpful!
    Have downloaded the manual but web site was not very easy to negotiate.
    President:
  • 987 Answers
After the tape rewinds and then I push the eject button, the tape doesn't rewind back into the cassette before ejecting.
This should also be happening when you just eject the cassette without rewinding.
NOT KNOWING THE BRAND, MODEL, OR NUMBER WE CAN ONLY DO SO MUCH!!!!
Best guess is a belt needs to be replaced.
Sep 19, 2016 | Televison & Video
Can not eject video cassette from RCA VCR model VR680HF
Best thing to do here is open unit and have a look--likely the tape is bound up on a post or something--usual cause is the mechanism that rewinds/plays the tape is not working right----when eject is hit it rewinds and puts the tape back into the cassette.
This unit is old enough to have about 5 belts and a rubber drive wheel any of which if broken or bad will do this.
They used to sell a belt pack by model number with the drive idler--pretty easy to replace IF you can find the parts.
SD TECH
Apr 26, 2012 | RCA Televison & Video
Was rewinding a tape, then the unit shut off. Now will not turn back on. No power at all.
www.tacp.toshiba.com/tacpassets.../SD-v394/.../SD-V394_om_e.pdf
http://www.tacp.toshiba.com/tacpassets-images/models/SD-v394/docs/SD-V394_om_e.pdf
http://manuals.electromaniacs.com/category.php?id=176
OK above is some links for your user and a service manual.. use these to troubleshoot and hopefully repair your unit. This sounds like a thing called a Mode switch, inside the VCR going faulty. If you cannot sort it yourself, you need to take it to a Toshiba authorised service center and ask for a "Quote"
May 17, 2010 | Toshiba SD-V394 DVD Player/VCR
The one for all remote control model urc-7562 funtion on the menu doesnt work what could be the problem?
Hello Stephendo394:
Here are some advanced codes that were found on Remote Central.com web site.
003 Menu
004 Timer Recording
010 Timer Recording
024 Shutdown
026 Shutdown
036 Skip 30 sec
039 Next Page in Menu/Next Track in Play mode
041 Previous Page in Menu/Previous Track in Play mode
043 Time Slip
053 Record
055 Play
061 Right
065 AV
070 NTSC/PAL
076 Language Right
080 Language Left
084 Source
091 Source = SD
100 Playlist View
101 AV
105 Tape Speed
106 Advanced
116 5
117 1
118 7
119 3
120 6
121 2
122 8
123 4
124 Setup
127 Picture Info
140 ?
146 Record
148 Channel Down
152 Channel Up
162 HDD Management
164 Delete
178 Record Flexi-Mode
179 Source = DVD
180 Rewind
181 Returns to Menu
182 Pause/Play
183 Rewind
184 Forward
185 DVD In/Out
187 Forward
189 Context Menu
191 Enter
192 Up
193 Return
194 Left
197 Guide
198 Info
215 ?
219 ?
229 Create Chapter
230 ?
234 Display
245 9
249 0
Aug 20, 2008 | Televison & Video
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Funi vcr combi
theres probably something out of whack in the vcr probably one of the pins inside your best best if you want to keep it is to take it to a repair shop or if your handy open it up and see if anything is either stuck in there or bent.
Nov 30, 2007 | Televison & Video
Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Jun 20, 2007 | Toshiba V643 S-VHS VCR
Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Jun 10, 2007 | JVC Cybercam GR-DVL805 Mini DV Digital...
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
