Question about Symantec WinFax Pro for PC
How creat auto run ghost image
How creat auto ru ghost image
  • 143 Answers
This is not a WinFax PRO related question.
Posted on May 29, 2009
Tip
Always save a basic drive image to Optical media ie:> DVD-ROM you will thank me
Most New Laptops will come with a Factory Default image that will be hidden but can be accessed during the Boot stage by pressing a certain key combination like ALT + F10 or CTRL + F10 of it will have a firmware software like PC Angel LE like on the Evesham Laptops which will revert your Laptop back to how you bought it.
With Desktops this is not always the case and to prevent almost a days work fulling installing your PC back to a basic setting it is a good idea to create a drive image with the DOS and the latest service packs; plus latest hotfixes; microsoft office; printer drivers; web browsers + addons; Java; Flash and Shockwave, (you can go on forever well upto 4.2GB anyway)
These will easily fit on a single DVD-ROM (4.7GB) optical disc I suggest that you use Norton Ghost v14.0 it will take about 20mins to create and about the same to reload your PC with the image.
You will of course require a DVD Burner either ATAPI or USB if you use Norton Ghost you can also undertake a pre-boot Antivirus scan, I have created this script to allow you to create an uptodate Virus Defintions CD
http://rapidshare.com/files/312247455/getdefs4ghost_iso_burn.zip
Heres how it works unxzip the archive to your C: drive then run the getdefs32.bat first then put a CD-RW into your drive then run makecd4defs32.bat this will create an ISO then burn then latest Defintions to your CD use this by browsing for you D: drive after you have booted with your Ghost v12.0 or v14.0 boot CD and selected the antivirus scan option.
I created this as I got fed up of installing NAV2008 onto my PC while I was running McAfee from Sky just to update my Ghost v12.0 CD.
Hope you all like it .....join me at the www.windowstipsclub.co.uk on facebook for more of the same.
P.S You might have to run scanbusit.bat the mkisofs.bat is set to 1.0.0 you might need to change the line in the makecd4defs32.bat to asuit your system setup.
cdrecord speed=0 -dev=1,0,0 -dao -v VirusDef.iso
Shown here is the result for my system my Philips DVD burner is located at scsibus1 so my dev=1,0,0 this will need changing ONLY ONCE if your ISO will not burn as it can't find the drive.
on Dec 01, 2009 | Computers & Internet
I want to format my hard drive
If you have a true image to restore from, as like what is created with Win7 Pro Backup, or from Norton Ghost, you should be able to make a total restore. The destination drive had to be the same size or larger than from the drive the original image was taken from.
With Windows, you will require the image recovery DVD disk that are created using the OS that the image was generated from. With Ghost, you will require the Ghost recovery DVD disk to restore the image.
Jerry G.
Nov 19, 2011 | Computers & Internet
How to make ghost image of windos 7.
Are you reffering to Norton Ghost? If so newer versions require that you install the software on the pc itself, from there you can select to do a full disk back up which will create a system image.
If you have an older version you can actually boot from the CD-ROM on system boot and create your image from there.
Mar 13, 2011 | Computers & Internet
Is it possible to create one generic win 7 ghost image and use it on any pc or laptop. I've tried this in the past with xp and it was an epic failure; sometimes it worked after ghosting, sometimes it...
A ghost image can be used on only one computer the same image cannot be replicated on other machines. Create a different image for the other computers and then burn the image file to the DVD drive for future use.
Dec 19, 2010 | Computers & Internet
Hi, How do I recover my Office 2003 Auto Correct from Norton Ghost? I back up my PC image and formated my hardrive. Now I want to reover just my autocoreect file and apply it to my new Windows...
This will only work if the drive with your new Windows installation is larger than the drive with your ghost image.
Assuming that the above is true, do the following:
Using disk management, create a partition on your hard drive which is large enough to accept your entire ghost backup. Restore your ghost image to this partition and then select any files or folders you may need. Once you have the necessary files you can delete the partition again if need be and use it for other storage purposes.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
Dec 20, 2009 | Symantec Norton Ghost 14.0: Windows
Self installing image
Try Acronis True Image. Similar to Ghost but works better. You can create an image of your system on a separate partition. When booting your system, you can recover from this image by pressing F11. Sort of like the hidden partition some companies put on a hard drive to return it to factory state. Only you create the partition yourself.
Aug 08, 2009 | Computers & Internet
Tech master
TO CREATE UR OWN BOOTABLE CD /DVD U NEED THE SOFTWARE NAMED "WINDOWS POST INSTALLATION WIZARD " AND ABOUT THE GHOST U NEED TO 1ST CREATE THE IMAGE OF UR PARTITION WHEN UR OS IS IN GOOD STATE & AFTER THIS U R ABLE TO R ABLE TO RESTORE THE OS WITH THE PARTITION IMAGE
PLEASE VOTE FOR ME
May 11, 2009 | Computers & Internet
Acer aspire 5500 hard drive
I have used norton ghost to do just what you're wanting to do.
1)run ghost on a desktop pc,hook your 60gb hd to your pc as a "slave"(using adapter).
2)"clone",or"create image"of the hd to a folder (on desktop)
3)swap hd's(on desktop)
4)format new(250gb)drive as "ntfs"
5)open ghost,and do a "restore"-of the saved image folder-TO new hd,re-install new 250gig in laptop.
///YOURE done!!!
-now you will have a back-up(old hd,AND image file folder.
Dec 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Symantec WinFax Pro for PC Logo
588 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
