Question about Microwave Ovens
Stove top light won't come on my roper over the stove micromave oven model # MHE13XHQ. Have tried new bulbs but no luck. Is there a fuse to look for?
  • Microwave Ovens Master
  • 13,433 Answers
Looking at these diagrams.
http://www.partselect.com/MultiModels.aspx?ModelNum=MHE13XHQ&SearchTerm=fuse&RefineSearch=0
Part 6 is bulbs
part 7 is holder
part 4 is connector?
Unplug microwave, open it up, use a digital meter or test lamp on the connector and the bulb holders to check that the wires are okey and you get from both contacts.
there certainly are fuses inside the microwave, not very good diagrams available with full wireing info.. I think you will have to open it up and trace the bulb wires back into the source check for fuses on the way, and if you have no electronics experience and you don't have a test light or a multi meter, then i'm not sure if you want to perform this repair, it shouldn't be difficult. Just follow the wires and find the problem.
The problem could be bad bulb, already replaced, not that.
no contact on the bulb holder
no power to bulb holder - in that case follow and test the wireing.
possibly fuse
possibly faulty switch.
you can find more diagrams from here
http://www.partselect.com/MultiModels.aspx?ModelNum=MHE13XHQ&SearchTerm=fuse&RefineSearch=0&Page=2
Good luck and be carefull, its not a toy that your repairing and it holds deadly voltages when plugged in some components may hold deadly voltage even when unplugged.
Posted on May 16, 2009
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
I have a roper mounted microwave above my stove. i just need to know what kind of bulb goes underneath it.
Since you obviously intend replacing the bulb yourself (good for you!) you should first remove the old bulb and that will make it easier to find a new one. Chances are, its a common bulb, readily available wherever light bulbs are sold. Or, at the very least, a hardware store like Tru-Value or Home Base.
Feb 03, 2010 | Roper MHE14XKB Microwave Oven
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
How do I change the light bulb in the microwave - the one that shines above the stove? I removed the covering and tried to remove the bulb but it doesn't seem to unscrew and the bulb just came out - no...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "how to change cooktop lamps" for example.
Nov 24, 2009 | Roper MHE14XKB Microwave Oven
Down lights/night light not working
I'll do my best w/out model#... remove 2 screws top of the air vent grill to remove grill.. remove 1 screw at top of touch pad.. you will see maybe 2 or 3 diff fuse area...thats how you get to the fuse for your question.. but I think the relay in your control for the light is bad. unforturnately you have to replace the whole board (in most over the range micro) good luck.. mike
Jan 16, 2009 | Kenmore 62622 Microwave Oven
Bulb replacement
It aint haolgen. This is another GE piece of POO engineering.
Unplug the microwave FIRST.
Now, Make sure your stove top is cold!
There are 6 phillips head screws holding a plate that secures the stove-top light and grease trap filters on the underside of the microwave. Lay on our back on the cooking elements looking at the bottom and remove the screws. The plate should swing down on hinges in the back.
Then remove the "bulb holder" which is held inplace with another phillips head screw. You can see what it looks like: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100389
You should now be able to remove the "screw-in base" of the bulb with your hand or in my case, because I was so tight, I man-handled it with a pair of needle nose pliers.
Now, go find a bulb! good luck.
Nov 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Roper mw under cabinet light
You probably need to have the receptacle replaced that the bulb screws into
Oct 29, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
