Question about Fine Digital FineDrive 400 GPS Receiver
Stuck on welcome
When i turn on my gps system it stays on the welcome scereen  i was told by fine drive to hold down the buttions on the left side for 7 seconds but it did not work .cant contact company by phone or e mail to fix problem
  • Anonymous Nov 09, 2007
    When the welcome screen appears an error popup screen appears.
    I have not been able to get beyond the error screen.
    I have also not been able to contact any one by phone at FineDrive.
    Also my emails have not been answered.
  • wy-_-me Jan 03, 2008
    Same problem but can't justify buying software that is three years old. I take it Fine Digital doesn't support it's own product? My GPS is has their latest (2005) software.
  • 107 Answers
The finedrive screen stuck could be a firmware issue, you may need to reload the firmware. you can find disks for it on the finedigitalusa site.
the error coudl be a corrupted memory card, I had this once. it either give you an error or tells you the card is not inserted. again, the solution is to reload the card with map data.
Posted on Dec 28, 2007
MAGELLAN GPS 1412 STUCK ON SYSTEM SETTINGS SCREEN. The GPS worked fine yesterday, I took it out of the vehicle to bring it inside to program a trip, the battery was low so I took it back out to the...
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 16, 2011 | Magellan RoadMate 1412 Car GPS Receiver
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
When I stop and turn off my car, my Garmin 255W stays on. Hows do I turn it off?
If your GPS is plugged into your power outlet in your car, it just means that the power outlet retains power when your vehicle is off as well. Meaning it is not an "Accessory" power source. Not a big deal, simply slide the power button on your garmin unit to the left. The power button is located on the top left side of the GPS. It is spring loaded so when you slide it to the left, hold it there for a second then it will spring back into place. Just release it and the unit should power down.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Error detais was 0351
sounds like the Hard drive could be going bad and needs to be checked and or replaced.
you can run the scan disk on the hd to see if it is still working by holding down the 1&9 buttion at the same time while turning the main power on
you will see a little white box start to drop from the upper left corner of the screen and will continue till it is finished.
if running that doesn't fix the problem then you will hav eto have the hard drive replaced
Jun 04, 2010 | Canon imageRUNNER C3220 Color Copier
My Creative Zen started freezing a couple weeks ago. I would press the restart button at the bottom left and that seemed to solve it. Now though, when I turn it on, the Creative Zen welcome screen comes...
It sounds like the hard drive is damaged I have a archos 605 wifi it froze up on me so i turned it off and turned it back on and it wouldn't load pass the archos welcome screen come to find out my hard drive was damaged.Hopfully yours is still under warranty otherwise you'll have to send it in and pay to get it fixed but i would say the hard drive is damaged.
Nov 28, 2008 | Creative Labs Zen Touch MP3 Player
GPS-Finedrive 400
try holding the bottm right buttion on boot, should go to windows ce, if not you may be out of luck...
Aug 24, 2008 | Fine Digital FineDrive 400 GPS Receiver
Stuck with pre boot mode on screen
"Will not turn off, stuck on with display saying 'pre boot mode'. Does nothing but this - please help!"
This indicates that the on/off switch is shorted out. You can duplicate this problem by taking a working Nuvi and keep holding down the on/off button when turning it on. It will stay in this mode until you let off on the power on/off button.
- Jim
Jun 07, 2008 | Garmin Nuvi 660 GPS Receiver
Navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
Jan 12, 2008 | Navman F20 GPS Receiver
i think its your operating system that has a problem.. try reformating your computer.. hope it can help
Nov 06, 2007 | Acer Aspire™ T180 PC Desktop
Fine Digital FineDrive 400 GPS Receiver Problem
The company went bankrupt. I get a "unable to read map data error". Called for over a month, sent email after email. Finally contacted a company that fixes Finedrives and they told me the company (Fine Digital) is out of business and will not warranty the unit...ten months old at the time. The company who fixes these machines said that it would be cheaper to buy a new(different company) gps system compared to having them fix the Finedrive 400.
Oct 31, 2007 | Fine Digital FineDrive 400 GPS Receiver
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
85 people viewed this question
Top Fine Digital GPS Experts
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
