Question about Belling XOU252 Electric Single Oven
No Power to Belling 163 model
Suddenly had no power to Belling XOU 163. changed the fuse but still no power. Any suggestions?
    Problem Solver:
  • 18 Answers
Check the safty cut out, if there is one
Posted on May 16, 2009
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
The grill on our belling oven has never worked since we bought our house. Any ideas?
Could be the switch, the element that ate faulty or it could be the fuse that has blown. With a volt meter, check that there is power at the element with the oven set to grill. If there is power that rules out the switch and the fuse. If there is no power, check first the fuse and then look at replacing the switch. If there is power at the element, switch off the mains and do a continuity test on the element to check if that is faulty.
Feb 06, 2011 | Belling Ovens
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 11, 2010 | Belling XOU252 Electric Single Oven
My Belling oven isn't working at all- no power or
Be careful with one. Turn power off at the mains first then change the socket. I suspect the wires were loose in the socket and heated up and damaged the switch. If you have a continuity meter try checking between live in and out and neutral in and out on the socket
Oct 24, 2009 | Ovens
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling oven xou 179
Hi
you need to remove back panel in oven. from there you will see the element somtimes you can unscrew them from inside if not you will have to remove oven from housing . remove back panel and the element will be bolt from behind just remove these the refitt new element in reverse order. hope this helps you
regards dan
May 19, 2008 | Belling XOU174 Electric Single Oven
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Belling XOU252 Electric Single Oven Logo
248 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
