Question about Samsung Televison & Video
Intermittant humming noise from 56inch Samsung DLP....almost sounds like a motor when it happens...when it starts it kind of ''winds up to a certain pitch and when the tv is shut down, it winds down until going totally away''.
Did you find an answer to this? I have a 52" that has just started doing the same thing. TV is about 5yrs old
Posted on Feb 25, 2010
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
I have a 52" DLP samsung tv I believe the motor
It sounds like the color wheel needs replacement. Yes it can easially be done yourself. You can get the colorwheel with instructions from www.tvrepairworld.com
Sep 15, 2011 | Samsung Televison & Video
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Nice Samsung HD wide screen television that started making noise last week and this noise got proggressively louder and louder to the point that we cannot watch it now. It sounds like an internal...
Give me model number (it is on back and also should be on right side of cabinet)
I suspect it is a DLP set with a bad color wheel.
Wheel faces lamps in DLP type sets and bearings in motor fail causing either high pitched whine/fan like sound.
If wheel shatters set will shut down.
There are instructions and videos on You Tube for replacement of the kind of part---do it your self repair.
Look at photo and add comment here with model number.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Samsung Televison & Video
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Dryer problem
you need to either clean or replace the drive motor motors have two windings start and run windings both windings kick in on start up then the centrifugal switch kicks the start windings out and the run windings take over if nothing is jamming the tub go to the motor sme times getting the lint out of the switches and motor will fix it if not replace it
Jan 18, 2008 | Dryers
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
175 people viewed this question
Henry  Thomas
Henry Thomas
