Question about Altec Lansing ACS 90 Computer Speakers
What power supply is required. The rear input
What power supply is required. The rear input says 13VDC, 2A. I have an extra supply that puts our 12VDC, 1A. Will it work?
  • 2,567 Answers
No. It is not recommended to use this power supply, since it outputs only 12 watts of power, whereas the required power to run your speakers is 26 watts.
You will have to use a power supply which outputs 13 VDC, with at least 2A.
Posted on May 16, 2009
How can i charge my b&d 12volt ps130 batteries without a charger
A Dewalt 12 V or I use the universal charger works on my B & D Firestorm trimmers battery How technical are you I could Explain to you how to set up a 12V ( > 13VDC) power supply to the terminals on the battery but you have to be Extra careful not to over charge ! You can pick up Firestorm chargers for about $ 15.00 on Ebay
Jun 27, 2016 | Cars & Trucks
Engine will not start. Jumped out solenoid and engine starts but kills when PTO switch is engaged to operate blades. Any ideas?
yes but whats a 12 volt light bulb do that connected across the start solinod when the key is turned to start ?
id bet it don't lite! this is proof theres a high resistance fault in one of your safety switches (very common)
Sep 15, 2015 | Garden
Input power for a Buslink dvrw812d-u2f
DC output 12V - 2A / 2.5A. Center tip positive.
Link to purchase a power supply:
http://www.buslinkbuy.com/product.php?prod_id=281
Mar 13, 2014 | BUSlink Computers & Internet
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
Heading out the door to work, I accidentally grabbed the wrong power supply. My Coby CD-TV153, which requires a positive center, 13VDC power supply was plugged in to a NEGATIVE CENTER, 9vDC power supply...
its not always fatal depends on what is damaged internal
however it may be cost effective to just replace the unit
the power circuit in the tv needs to be checked and see what if any thing is damaged it then you can make a asesment of repair
Nov 04, 2009 | Coby CD-TV153 5 in. Television
I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Sep 14, 2009 | QPS (QU2RCT7) 7-Port USB Hub
External drive power supply 3 wire code???
Hi there.
Have a look at this link for wiring instructions >>>>>
http://www.pc-user.co.uk/power_connectors.htm
Hope this helps and thanks for using FixYa!!
Apr 21, 2009 | Computers & Internet
Problem with minebea atx power supply
The one extra cable with the small socket may be for the newer computer that require a power imput to the CPU. Also some of the more poswerful Viseo cards also require their own power cord supply. Many ATX power supplys have extra leads not being used .
Feb 12, 2009 | HP/ Minebea 160w ATX Power Supply...
NEED SPECS FOR POWER SUPPLY OF DDV-1100X
have the adaptor you require....model AD2910-0207 INPUT :- 100-240VAC, 50/60HZ 0.3A OUTPUT:- 5V -2A....AC ADAPTOR hope this helps....hope you can help me i have no software (drivers) for this camera. can you assist. pete
Jan 17, 2009 | Cameras
Rode NT2-A
No. This is an analog microphone that requires no drivers. Check that another microphone works into the same input (and check that the phantom power supplied at the input meets the NT-2A specs).
Nov 09, 2008 | Rode (VIDEOMIC) Professional Microphone
Altec Lansing ACS 90 Computer Speakers Logo
1,728 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
