Presario desktop wont pwer up - Computers & Internet
  • 1 more comment
  • mrninja
    mrninja May 11, 2010
    lets start at the beginning.. be sure the outlet is LIVE, do any lights come on the tower? are any lights on in the back of the tower? are any lights on -on the MOBO? does the fan on the power supply turn on?
  • stoneheaded May 11, 2010
    You need to give a lot more information about you problem. Type of computer with processor type and amount of memory and all all other components use in the computer setup. Cables used, is the computer used alone or in a home network situation.What were the problems you were having before the failure.Have you noticed any burning smells or experienced any strange noises coming from your computer before it failed. Have you open the computer up to check and see if there is any visible damage. You may need a friend to check out the computer for you then give more details about your problem.
  • anth1 May 11, 2010
    what happens when you press the power button? have you had any problems before now?
  • 59 Answers
I have a Presario desktop as well and if it won't power on than you need to check your connections and make sure everything is plugged in where it needs to be and that the connection has been established.- Meaning that all the connections are snug and tight - where they need to be. If that still doesn't work than something isn't installed correctly and you need to reset everything back to the manufactures settings and start from the beginning - These are your "F" keys from startup it will show you and prompt you/guide you to where you need to go to establish this. Vista is setup to guide individuals that are not computer savoy to fix their problems you just have to apply yourself and follow the instructions given to you, play with your system it will tell you.
Posted on May 17, 2009
Wiring diagram compaq presario hp h10025 product
you wont find one... and not sure why you need one.... if your changing the case then trail and error wont hurt anything
Oct 03, 2013 | Compaq Presario Desktop PC
I have a compaq presario SR1303 Wm Desktop I wont connect to internet, stating that local area cable is unplugged, however this isn't true because I have another desktop same model that works fine...
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Aug 31, 2012 | HP Compaq Presario SR1303WM (PP150AAR) PC...
Compaq presario sr2150nx ata 100 motherboard fan plug
The CPU fan is being detected, but there is a problem with compatability or there is a fault in the fan it's self. Have you tried your original fan?
Mar 10, 2012 | HP Compaq Presario SR2150NX PC Desktop
Hp sr2023wm core just shuts down. boot back and shuts down again! runs for hrs and then poof down again. possibly a power suppy? or an overheating processor?
If you are overclocking the processor it may be overheating.
ALSO check that the fans are running, including the one on the processor AND vents and heatsink fins are not clogged with dust.
Also consider if your pwer to the unit MIGHT be glitching or brownout due to heavy loads or bad receptacles or wiring. Make sure you are not running off a switched wall receptacle.
May 02, 2010 | HP Compaq Presario SR2023WM PC Desktop
Compaq presario sr5433wm-b desktop. the cpu will not come on, the green light on the back is blinking.
Check small switch on pwer supply (red) make sure it is in the 115 volt area. Sorry if this does not work sounds like a bad power supply...
Nov 17, 2009 | HP Compaq Presario SR1750NX PC Desktop
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
The cd tray on my compaq presario desktop wont close
The drive should be replaced. they are fairly cheap (like under 50 bucks) and simple to install. sorry about your untimely issue
please rate
Mar 03, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
