Question about Acer TravelMate 240 Notebook
Keeps turning itself to standby mode
I have a new laptop just set it up ...(acer 7530-5124 travelmate)..the problem is it's keeps shutting it self down to standby mode..it could be a couple of sec from starting it up or 10 to 20 mintues....i check the the power options settings and also installed to factory default twice...nothing worked.
  • UCW Computer May 20, 2009
    I Sold 4 of them, 3 returned with the same problem. Acer DonĀ“t give a damn, support is horrible. Keep sending it back.
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
Cant leave laptop cause screen wont come back on
It would seem that for some reason, the display would not activate again after going to standby. This would involve checking the inverter circuitry that powers the CCF lamps (backlight).
A possible temporary workaround is to disable/deactivate the "Turn off monitor" feature in your laptop's Power Scheme.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Acer TravelMate 2300 Notebook
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Acer Extensa 4630. The screen is blank but the computer is running. The acer screen appears upon start up but then the screen turns black. Any suggestions?
have you enabled "standby"mode,you usually have an option when shutting down.Either this or go into settings and make sure you havent adjusted sleep mode for the screen
Sep 10, 2010 | Acer Extensa 4620 Notebook
Reset acer laptop to factory settings
During the system bios boot press and hold ALT + F10, that should start you into the system recovery options.
Oct 30, 2009 | Acer TravelMate 2300 Notebook
When I plug in my Iphone computer shuts down
It sounds like your usb port is damaged. Look in the port and see if there is any visible damage. Also, check the usb cord for the iphone and see if it is damaged.
Please take time to rate.
May 13, 2009 | Acer TravelMate 2480 PC Notebook
Acer travelmate 2420
Its sure the heating issue in your scenario...try cleaning the thermal grease and putting new......get the heat sink and fan free of dust
Nov 10, 2008 | Acer TravelMate 2300 Notebook
Acer laptop keeps rebooting
fdisk /mbr then format the drive and reinstall your operating system.
Aug 29, 2008 | Acer TravelMate 4150LCi Notebook
It wont start up
Could be this is a driver error on boot up, when it starts to boot up keep pressing F8, this will bring up the safe mode menu, look for the line and highlight 'Last Known Good Configuration' and press Enter. If this works all is well, but if not press F8 again o boot up but this time highlight the line 'Start Windows in Safe Mode'. If the laptop then boots up in safe mode without shutting down, run your anti virus and spyware programmes. If non found and the laptop still has'nt crashed, then it's a driver problem (as not all the drivers load up in safe mode) and you will need to try a system restore to before the problem started.
Oct 30, 2006 | Acer TravelMate 4150LCi Notebook
Acer TravelMate 240 Notebook Logo
546 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
