Question about Dell E173FP 17" LCD Monitor
Vertical line Dell E173FPC 17" LCD Monitor Problem: Subject: We repair the power supply we chage the ic SG 68410 and one fet plus one cap .after this the screen is working ok .only problum with one small .5mm line is commoing on on vertical right side of the screen. we experience with videos reparing this type come if tantalum cap with polarity is nleaky. in this board we cant fined any. If u can send us the circuit diagram . we will be thankfull to you.Regards.MuzzafarGolden Finger Electronics EST  East Riffa 901 Bahrain .  e-mail rajamkhn@batelco.com.bhrajamkhn_1@hotmail.com973-17775475
  • 44 Answers
My dear did u check the polyester capacitor in that section or the paper capacitors. these lines occurs due to change in the frequency. might be helpful to you.....
Posted on Feb 08, 2008
Will not switch on, no green light totally dead?
These units are known for having issues with the internal power supply board. There are parts called capacitors that fail due to heat buildup in the monitor case. When they die the power supply stops working and you get a dead monitor just like you have. If you can solder then you should be able to repair your unit. We have a free step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ The repair should take less than 20 minutes to do and cost less than $15 for parts.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 15, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Wont display anything, green light on power button keeps flashing
The flashing light on the Dell E173 series indicates a failure in the power supply board. This series has several versions on the board so you will need to know the exact model, it is listed on the label at the bottom of the back cover. The versions are E173FPc, E173FPb and E173FPf. We have repair instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ that cover each version on the unit. The repairs will require replacing a few pars that will need to be soldered.
Buddy
Corporate Computer
www.ccl-la.com
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
I have a Dell E173FPc monitor. The power flickers on and off.
The blinking power light usually indicates a blown power supply board. We have a step by step repair guide posted on our web site at: www.ccl-la.com If you don't want to do the repair yourself we do offer a repair service. If you have any questions just contact us at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 23, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Stuck in sleep mode
When you say stuck in sleep mode if you mean the power light blinks and no picture then the internal power supply has died. This is a very common problem on the Dell E173FP series of monitors. That series has 3 different versions and each requires a different repair procedure. Check our web site at: www.ccl-la.com We have repair guides for many LCD monitors and the E173FPb, E173FPc and E173FPf versions are included. If you don't want to do the repair we do offer a repair service for $30 plus return shipping.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 09, 2009 | Dell E173FP 17" LCD Monitor
Monitor goes blank after a second after power outage
what happend is your monitor cought the brown out and the power supply capcitors are not defective and what that means is the monitor needs to be repaired there is no quick fix please rate accordenly thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" LCD Monitor Problem:
Although similar, this monitor and the associated repair is different than the "b" version. The link above is good to follow for finding out how to open your case but the actual repair is different. If you have minor soldering skills (really the de-soldering is the hard part) and can use a phillips screw driver you can make this repair.
I contacted Tom at a link I found on the "b" site and he sent me the typical components to fail for the "c" monitor. $20 and $1.35 for shipping. The site looks to be down now so I'm not sure if this is temporary or he's stopped selling parts. He is also willing to fix the board if you send it to him. Here's what you need to do:
Replace C922 and C923 with 1000uF 35V caps
Replace c924 and C925 with 470uF 25V caps
Re-solder L201 and L202 with fresh solder.
I did all of the above and the monitor works perfectly. When you take the monitor apart make sure you note where the blue and pink wires go (you'll know what I mean when you get to that stage). The connectors are identical and it would be easy to forget which way they were installed.
Sep 16, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
184 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
