Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Printing problem when i print my paper, i have a couple of black lin es that comes out on the right side of the paper
    Problem Solver:
  • 8 Answers
Before we can diagnose the problem, we need a little more info.  Do the internal prints (TX/RX report) also print the line, or only copies?
Posted on Oct 17, 2007
The pages are printing off center.
A black section down one side of the page could be a couple of things.
1) The Corona Wire Cleaner (The sliding piece on top of the Drum Unit normally either Green or Blue) is not at it's correct rest spot which is where the arrow on the slider and the arrow on the drum unit meet.
2) There is something stuck on the drum or in the laser. Check that there is no scraps of paper caught up in the workings.
Printing too far to one side can be caused by a misalignment of the laser. Turning the machine off for a few minutes may rectify the problem. Otherwise the paper is placed in the tray off-center. Make sure the paper uides on the tray are set snug on the paper.
Hope that helps
Mar 04, 2016 | Brother HL 5140 Laser Printer
Ir 33o double side printing problem
Depending where the paper is getting jammed at, take of all rubber pads off the right door. Several places like on each side of the guides. I can think of six pads that need to be removed. They are black and about 1/4 inch wide. Sometime they get sticky and cause the guides in the duplex area to not function correctly.
Sep 01, 2014 | Canon iR330-400 PS Ver 1.0
Why is it when using black it only comes out grey on the far right side
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
Jul 14, 2014 | OKI C5150n Led Printer
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Paper wrinkles on one side when comes out of printer
hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
Jan 31, 2010 | HP LaserJet 1300 Printer
Panasonic KX B520 does not ptint
I'm not sure if this will help, but we pulled my Panasonic KX-B520 printing whiteboard apart to find out why it didn't print. After a couple of hours and much head-scratching we figured out the paper was in the wrong way around. The printer was working fine, it just couldn't print on the wrong side of the paper. Even though the diagram on the inside of the paper bin showed the the print side of the paper on the outside of the roll, this particular paper roll had the print side on the inside. Answer? Put the paper in the other way around. It works a treat.
To see which side your paper prints on, hold a match or lighter to one side of the paper and see if it goes black from the heat. One side will, and the other won't (well, it will burn, but not like the other side. Use your common sense here.) The print side of the paper should contact the horizontal metal strip at the top of the paper holder bay.
Good luck. I hope my answer works for your problem, because it's so easy to resolve.
James from Canberra.
May 03, 2008 | Office Equipment & Supplies
Ink problems
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
Lexmark x1180
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
60 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
