Question about Toshiba 50H13 50" Rear Projection Television
Toshiba 50h13 hyperboard
I need a Toshiba 50h13 hyperboard. I was told it needs to be "rebuilt" and I'm thinking it might be cheaper to just get a new one with the upgraded caps on it. Anybody know of a source for the board? Thanks.
Http://www.hdtvoice.com/voice/showpost.php?p=122387&postcount=7
Posted on Oct 19, 2007
SOURCE:
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
Card reader replacement
I suspect that it won't play any source that uses progressive scanning. The likely problem is the hyperboard or scaler board. This component allows the TV to switch from sandard definition TV to HD. Typically, the hyperboard will cause shaking and wiggly images especialy noticeable at the top of the screen. It will generally work better the longer its on. Expect to spend $400-500 to resolve this.
michtech
Dec 09, 2008 | Toshiba 65HDX82 65" Rear Projection...
Hyperboard repair Toshiba TSB
Best way is to check in circuit with ESR meter........
EDS-88 CapAnalyzer..... www.eds-inc.com .........................
Mar 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Video has squigly lines in it at the top of screen ..
Small board called a hyper module bad .....can be rebuilt be
skilled tech or sent for rebuild..........................T.
Jan 10, 2008 | Toshiba 50H13 50" Rear Projection...
LINES AND FLICKERING
Probable bad Hyper module = no longer available...can be
rebuilt by skilled tech or sent to a rebuilder like PTS Corp.
Nov 14, 2007 | Toshiba 50H13 50" Rear Projection...
You need part #23148024.  The part is NLA.  I have 1 in stock or you can send yours to PTS electronics 800-844-7871 for rebuild.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Toshiba 42H83 42" Rear Projection...
Deteriorating picture quality at power up
It sounds like you need a hyper board for this. This part may not be available form Toshiba but I think I still have some in stock. You will likely have to have a technician insatll this for you.
Aug 27, 2007 | Toshiba 50H13 50" Rear Projection...
TOSHIBA 57 H 81 wont play 480p any more Green Screen
this happened to me once and what i found was that i had missed a defective component.. these parts need to be checked for ESR also check the solder connections....john
Aug 24, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 50H13 50" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
