LG 42PX5D 42 in. Plasma HDTV Logo
Posted on May 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG 42PC5D plasma TV and there's a sound delay on all channels. I'm using a HDMI cable from a Comcast DVR convertor directly to the TV. Is there a firmware update that's needed? If so, how do I obtain it?
Anonymous
Level 2:
  • Expert 187 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Answers
187
Questions
Helped
99190
Points
459
Firmware is mostly used by commercial TV´s, try using your TV with other device or an aerial antenna.
I believe the problem is your comcast DVR convertor.
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 • LG 55LM6700
3helpful
3answers
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
I have a RCA RT2906 surround sound reciever. I have an Insignia NS-32L550A1 HDTV. I also have a PS3 and a Comcast HD DVR. I've hooked all of these up according to the manual (with HDMI cables), and I...
You should have your signal in to your Comcast, then HDMI out to Sat in on your receiver. I haven't looked but I'm guessing you have multiple HDMI in on your receiver, but remember, you only have one HDMI out from receiver which would go to tv. What happens if you hook HDMI directly friom Comcast out to HDTV in.If you still have a delay there must be some sort of adjustment on your tv. When you plug into tv, Is it a default screen you can't change or, can you check say video 1, etc.? How many HDMI inputs do you have on your tv? Let me know through "add a comment"
Dave
3helpful
3answers
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
7helpful
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
1helpful
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at [email protected]
Good Luck!
16helpful
3answers
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
6helpful
2answers
No Non-Hd sound
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
