Question about Hitachi 61UWX10B 61" Rear Projection Television
Convergence Problem The overall picture is darker than usual a has a a blue offset duplicate image and a yellow duplicate offset image. It looks like a bad 3D moview without the glasses. The magic focus does not correct the problem and when attempting to correct the convergence manually, the grid lines all appear in white.
  • Anonymous Dec 05, 2007
    I have the same problem with my tv. I have been looking that issue up and I am thinking that I need to replace the IC's on it.
    President:
  • 4,402 Answers
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
replace convergence ic
Posted on Dec 31, 2007
Hitachi TV repair
Hello... Rear Projection TVs are not easy to work on. That being said, color issues can be caused by several different things. The most common involves the CRTs (there are three small picture tubes). There is a fluid in each tube that over time can dis-color, and involves a very difficult procedure to fix. Next, there are convergence circuits for each CRT, and one or more can fail. This will not usually cause the symptom you are describing, it will usually cause a double image in some or all areas of the screen and some areas the colors will look fine while other areas will not. It could also be a bad CRT drive board, or the video processing IC. It could even be the high voltage splitter! If I were you, I'd consider a new TV (please get the extended warranty). I hope this helps...
Nov 26, 2017 | Hitachi 46F500 46" Rear Projection...
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
My 53UWX10B has a picture problem. Picture is blue and yellow and the yellow is offset to one side a couple of inches. Gives a "ghost" image.
If the picture is 3d looking in some way----it is a convergence problem; many of these sets have "magic focus" and if it will not correct the problem the two convergence chips need to be replaced---this model should use either STK-392-110 OR -150 CHIPS.
This can be a do it yourself repair if you have some skill and total parts cost on Ebay would be under 25 dollars.
Let me know your skill level here and I will instruct you how to do the fix.
SD TECH
Aug 04, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Projetion tv showing double picture
you eed replace the convergence kit, (2) stk-392-560 ,and the picofuse 5 amp in your pwr.s.
Jan 14, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Blue outline around images on screen and also on menu yellow offset. picture was fine. I have tried convergence and did not help
Have the convergence IC's replaced. Only one has failed but have both IC's changed as the other is not far behind..
Thx please leave comment
Oct 08, 2009 | Televison & Video
Picture problem
start checking caps w esr meter probally leakey cap or solder conn.
Apr 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Convergence Problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
