Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Washing comes out smelling horrible! Any ideas?
HI I have a Hotpoint WD420 and the washing comes out smelling foul. Any suggestions?
  • Hotpoint Master
  • 3,463 Answers
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
Please rate my solution.
Thanks.
Posted on May 16, 2009
Smell coming from washing machine like stagnant water-hotpoint wma 44....seems to be coming up through the drain in sink
Hi from retired Englishman in France,
If the smell is coming from the drain in the sink, it is more likely that THERE is the problem rather than the washing machine. Washing machines deal only with 'dirty' clothes whereas sinks have all sorts of things going down them! You could have a partially blocked u-tube (not to be confused with YouTube!) in the sink because normal (changing/flowing) water in the u-tube should block smells coming from the main/foul water drainage system.
I would definitely investigate the sink! If it is not practical to remove the u-tube, use a propriatory sink cleaner ensuring that it is the right one for the job- OK for plastics or OK for metal (not chrome).
Good luck,
John C
Jan 25, 2011 | Hotpoint Washing Machines
I washed some clothes with petrol on them now the washing and washing machine smells of fuel, how do i get rid of the smell of petrol from my washing machine? thanks Chris
Run the machine with no clothes, only detergent along with washing soda or baking soda, using hot water. Once or twice with this should do it.
Feb 20, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Bad smell coming from washing machine
It probably is related to your drain outlet, depending on the set-up, I would suggest you remove drain hose and clean the place where the drain hose enters the drain system, if possible, clean all associated pipework
Thanks.
Sep 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420 clunking noises
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
May 17, 2009 | Washing Machines
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
It´s a wd420. We
Did who ever install this machine make sure that it was installed correctly and draining properly. The burning smell will go away with time.
Apr 13, 2008 | Washing Machines
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
478 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
