Question about Ovens
DOOR PROBLEM BOTTOM DOOR DOES NOT STAY COMPLETELY CLOSED. I HAVE TO PLAY WITH IT TO GET THE INTERIOR LIGHT TO GO OFF. THE HINGES SEEM TOO WEAK. ARE BETTER HINGES AVAILABLE? I AM VERY HANDY. HOW WOULD I REPLACE THE HINGES?
  • EPPYMAID Oct 24, 2007
    I can take the door off just as you noted but I need directions to take the door apart to change the hinges.
  • Anonymous Mar 14, 2014
    hinges are not working correctly
  • 74 Answers
I am not sure about your oven model.  I had a similar problem in my oven.  The hinges are riveted to the oven and can be fixed.
First remove the oven door - normally the door slides on to two prongs on either side and is screwed down.
Once the door is removed check the mechanism that holds the two prongs to the oven body.  Mine were held with stainless steel rivets that had worn out and became wobbly.  Cut the rivets and replace them with new ones.  You can get a rivet driver and the stainless steel rivets for under $20 at Home Depot.
Hope this works for you.
Posted on Oct 16, 2007
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
The oven door does not close properly and stays open enough to keep the light on. Whirlpool Gold, Model GR399LX60
If it has a drop down door with hinge on either side, then only solution is to replace both door hinges, as the problem is usually due to weak door springs, and they are not adjustable.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Whirlpool Ovens
Door does not close completely. Light stays on
weight on door, hinge got bent, door out alignment, light stays on,you can try to bend the hinges back, but i'd suggest replacement
Jan 31, 2010 | Ovens
Oven door does not close properly, light stays on.
Check the hinges at the bottom corners to see if the spring is still connected and see if the hinge is wore out. The door lifts off the hinge when it's in the partially open position after loosening the screw holding the door in position on the hinge. Slide the oven out a little to access the hinge to replace or inspect.
Jan 01, 2010 | Kenmore Ovens
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Ovens Logo
399 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
