Question about Samsung L200 Digital Camera
Where is memory card opening?
I have looked and looked, do not find memory card slot for Samsung L200
    President:
  • 2,761 Answers
Looks like it's in the battery compartment. Here's a link to the owners manual for your camera:
http://downloadcenter.samsung.com/content/UM/200902/20090202155610968/L200_English.pdf
Bill B.
San Antonio
Posted on May 16, 2009
How to download a video from samsung L200 10.2 megapixel to my computer?
ALTERNATE WAY TO TRANSFER VIDEOS AND PHOTOS TO COMPUTER
If your videos and photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 23, 2012 | Samsung Cameras
I am trying to upload pictures i took from my L200 Samsung camera by connecting the pc and the camera with a usb cable. But everytime i do that the camera suddenly goes off. I then look for it in '
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Jan 26, 2012 | Samsung L200 Digital Camera
How can i transfer my p;ictures from my camara samsung l200 to my memory card because is not saving them?
Welcome to FixYa.
One possible reason is that your memory card is not yet formatted for camera use.
Image or recoridng will be automatically be saved in your memory card, if card is inserted. If not, it will be saved on your internal memory.
Second reason is it is in write protection.The SD/SDHC memory card has a write protect switch that prevents image files from being deleted or formatted. By sliding the switch to the bottom of the memory card, the data will be protected. By sliding the switch to the top of the memory card, the data protection will be cancelled
Before taking pictures you have to slide the switch to the top of the memory card.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 12, 2011 | Samsung L200 Digital Camera
Hello there, I have a Kodak SD card in my Samsung camera. When I have the card in the camera, I can view the pictures on the camera screen fine. However, when I insert the card into the computer, it...
If you can also view the pictures on the camera with no card inserted, it means the pictures are actually on the camera's internal memory. Try that first. Next, understand that sometimes the built-in slots on a computer can stop working for no apparent reason. Get a separate card reader and try that. typrice_104.jpg
Jan 21, 2011 | Samsung L200 Digital Camera
How do I unlock a card when I try to take a picture?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Sep 04, 2010 | Samsung L200 Digital Camera
I have a samsung l200 and when i scroll through ther pics on the camera it will freeze up
It is your memory card in your camera. I would donwload the pictures to your computer first. Then insert the card into your computer and format the card. The problem is that your card is corrupted somewhere and it needs to be re-formatted.
Dec 11, 2009 | Samsung L200 Digital Camera
Corrupted photos
A generic fix for cameras with this problem is to FORMAT the memory card. Simply erasing the card is different from formatting. A freshly formatted card wipes all information from the card - making appear (almost) NEW.
Save all desired pictures from card before formatting, as once the format process has been completed, it is *nearly* impossible to retrieve any data from the card.
If the problem continues, the card itself may have been corrupted, and should be replaced.
I hope this helps!
Oct 26, 2009 | Samsung L200 Digital Camera
Card locked
>look for a lock tab at the side of it
>push it up
>insert the memory card back.
>that should do it
*card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
hope this helps
Feb 20, 2009 | Samsung L200 Digital Camera
Samsung L200 camera
there should be a sliding switch side of the memory card just slide it to unlock..
Jan 31, 2009 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
70 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
