Question about Frigidaire Affinity ATF7000ES Front Load Washer
Not hot water EF0 code
Start Frigidaire ATFB6000ES1 washer using hot water only. Washer makes a loud thumping noise and no water in the drum EF0 code flashes. In warm water mode their is no hot water, only cold and E10 code flashed repeatedly until enough cold water fills drum with repeated restarts. Checked hot water supply hose everything working fine.
  • 6,784 Answers
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
Posted on May 20, 2009
Frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Loud noise during rinse cycle
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Frigidaire Washing Machines
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Washing Machines
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
307 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
