Question about Nikon Coolpix S210 Digital Camera
Memory card will not stay down in a nikon coolpix s210
When i put the memory card into the camera it pops back up. if i work real hard i can close the door and keep the card in the slot but when i turn on the camera it does not always register that the card is there
  • yourgilr0876 May 21, 2009
    Memory card won't stay down in my Nikon D-40.
Hi, I have exactly the same problem. However, instead of getting a new body with a broken screen and exchanging my screen (One of the only ways round it) I thought I'd try something.
I folded a piece of paper (Quite a small piece) and put in on top of the card when it is popped. I then just closed the battery/card cover and it stayed in place. This is a cheap way of fixing it, it's now been fine for a while, it's a bit of a shoddy fix but it's better than paying nikon £50 to get it fixed.
It takes a couple of trys, getting the paper the right size was a little bit of a pain but it now works fine.
Good luck,
J
Posted on Jun 16, 2009
  • skinlaser13
    skinlaser13 Jul 01, 2012
    Thanks!!A ton...............This solution worked successfully for me too!
  • 4 Answers
I had the same problem with my Olympus sp-550uz. I took your recommendation and it did take a few tries to get the paper right and get the memory door closed but it worked. Thank you so much I was tring to decide what to do with it as it was $150.00 or so to get it fixed at Olympus. I am so happy!!! Thank you so much
Posted on Jul 19, 2009
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
My nikon coolpix s210 camera wont download pictures, and when i plug it in, nothing pops up like it usually does. what do I do?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Aug 18, 2011 | Nikon Coolpix S210 Digital Camera
Consider NOT connecting your camera to your computer.
Can nikon colpix S210 be used for webcam.
You can't. The S210 was designed as a camera, storing high-resolution pictures (and videos) to a memory card. It was not designed to stream low-resolution videos live to another device.
Jun 20, 2010 | Nikon Coolpix S210 Digital Camera
I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Aug 06, 2009 | Nikon Coolpix S210 Digital Camera
I cannot download from the S210 onto my laptop
Capture beautiful memories perfectly with a high quality battery for your Nikon Coolpix S210 digital camera. Rechargeable Li-ion 3.7V 660mAh Nikon Coolpix S210 battery for sale,20% Off! Full one year warranty! Website: http://www.nikon-coolpix-replacement-battery.com/coolpix-s210.htm
Jul 26, 2009 | Nikon Coolpix S210 Digital Camera
New 4GB Skandisk card, no memory and no images message
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Pop it back in the camera and use the menu to format the card.
Hope this helps
Regards
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
Nov 24, 2017 | Nikon Coolpix S210 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
648 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
