Question about Whirlpool GR450 Electric Kitchen Range
Whirlpool Gold Self Cleaning Convection Oven Model # GR450 LXXT0 with Accusimmer: Right-Front element gets hot but not Red Hot. Happens when first turning on element from room temp; never gets red hot. Other elements get red hot from the git-go. Is it a bad element or the control? How do you access either/both? Seems like a bad element should be go-no go. CRW Waldorf, Md.
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
IFIXALL
  • 868 Answers
SOURCE: How to replace the bottom
Do you mean stuck by melted or shorted into the case?
Posted on Jun 12, 2008
SOURCE: Oven element started to spark
See this for description of same issue:
http://forum.doityourself.com/appliances-large-electric/255234-ge-electric-range-oven-element.html
Posted on Jan 24, 2009
ethelpilgrim
SOURCE: bottom element needs replacing
the side right side panel comes off three screws hod it on the back pullout
Posted on Feb 08, 2009
SOURCE: Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Posted on May 26, 2009
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
Oven will not get hot,but when i use self cleaning oven it gets real hot
If you do not see your bake element get red hot during the clean cycle then the bake element is bad and needs to be replaced.
Aug 04, 2011 | Kitchen Ranges
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool GR450 Electric Kitchen Range Logo
360 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
