E 100, e 301 error
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
SOURCE: canon xerox ir 400 error
This problem due to your composite power supply,you can see 3 blue capasitor has burned,change it with 4 amp fuse near that caps
SOURCE: error code
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
SOURCE: e805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Hi ladman mubar, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
I unnkowingly kept the machine on while replacing the pickup section after replacing the pickup section the error code e 805 is showing,after asking to close the front door.
