Computers & Internet Logo
Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SMTP using the EtherCard Arduino library
Ok - lets see how good fixya can do. Looking for a way to send mail alert from an Arduino using a ENC28J60 module (via the Ethercard.h library I was thinking). There are no php server scripts, No RaspberyPi servers or otherwise available to be used - just a SMTP server I want the arduino to talk to. Can anyone find anything that works? I can request webpages - but the persistent TCP connection for SMTP is proving a challenge. Thanks.
Loucke Bodman
Level 2:
Champion:
  • Expert 242 Answers
  • Posted on Dec 21, 2013
Loucke Bodman
Expert
Level 2:
Champion:
Answers
242
Questions
0
Helped
46209
Points
347
This sounds like a great project, and I wouldn't mind downloading your code when you finish!
2 Related Answers
Anonymous
  • 948 Answers
  • Posted on Jun 22, 2009
SOURCE: connection to server fails using outlook express trying to send
According to Yahoo's page that is not the correct server.
Anonymous
  • 22 Answers
  • Posted on Jun 02, 2011
SOURCE: Can't send outgoing E-mail, connection
You need to change your port for your outgoing mail server. If it's yahoo you are using you need to use the following settings in outlook:
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (SSL enabled, port 465)
Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (SSL enabled, port 995)
You have it set to port 502, it should be set to 995.
If you are using Outlook 2010 click on "File" and "Info" on the left. Click on the Account Settings box and find your yahoo mail account.
Double click on your account and in the box that pops up, you will see a button on the bottom left of it that says "More settings." click on that.
Click on the "Advanced" tab that you will see to the very right and change the setting for your outgoing server. It should say 502 in the text box. Change it from 502 to 995.
Need to know the information on the SMTP mail server for Hotmail and the SMTP server port and it is also saying About the SMTP server port 2 as well which I don't understand. It would be great if I co
Hello, basically an SMTP server is a mail server so your system can send you the alerts. Please check this URL: http://email.about.com/od/accessinghotmail/f/Windows_Live_Hotmail_SMTP_Settings.htm
4answers
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
1helpful
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
HI, i have facing some problem i send a mail using my domain " (caresoftinc.com ) " in yahoo email addres geting erorr :- This is an automatically generated Delivery Status...
This behavior may occur if the outbound security of the Simple Mail Transfer Protocol (SMTP) virtual server or the outbound security of one or more SMTP Connectors are set incorrectly
To verify whether this is the cause:
  1. Open Exchange System Manager.
  2. Expand Servers, and then expand ServerName.
  3. Expand Protocols, and then expand SMTP.
  4. Expand Default SMTP Virtual Server, and then expand Queues
Remote Delivery Queues will be displayed in retry mode (A Blue Arrow).
To view the description of the queues in retry status:
  1. Right-click a queue in retry status, and then click Properties.
  2. The upper status box should read, "Retry, Remote delivery".
  3. The lower box should read, "The remote SMTP service rejected AUTH negotiation".
Using DNS for Delivery
  1. loadTOCNode(2, 'resolution'); By default, Anonymous access is the default setting for sending SMTP mail by using DNS to all Internet domains. To resolve this behavior:
    1. Follow these steps to change the SMTP virtual server:
      2. Expand ServerName, expand Protocols, and then expand SMTP.
      3. Right-click Default SMTP Virtual Server, and then click Properties
      4. Click the Delivery tab.
      5. Click Outbound Security.
      6. Click to select the Anonymous access option, click OK, and then click OK again.
    2. Follow these steps to change the SMTP connector:
      1. Locate, and then expand Connectors.
      2. Right-click SMTP Connector, and then click Properties
      3. Click the Advanced tab.
      4. Click the Outbound Security button.
      5. Click to select the Anonymous access option, click OK, and then click OK again.
      6. Close Exchange System Manager.
Dec 15, 2010 • Yahoo Mail
In Yahoo mail. Will not send email. Says "Processing your message". Never sends. I am receiving my emails as usual.
If you use any email client like outlook or other then make sure yahoo smtp server and smtp port are configured properly. If you use web based yahoo and receive this error then there is problem at yahoo server side . For that you need to contact yahoo customer support for fix this yahoo email server issue. Let me know if you need further assistance. Thanks for using FixYa.
Oct 13, 2010 • Yahoo Mail
1helpful
Cannot send email ,receive ok
first turn off sync Mail accounts in iTunes and remove the mail accounts in the iphone, then with openss from my windows WinSCP set permissions /var/mobile/Library in the folder "Mail" to 777, now itunes can sync yours mail accounts, then go to iPhone open icon Settings into then go to "Mail, Contacts, Calandars" option and go Accounts "xxxx" -> SMTP here set the username and password for ur account and delete other SMTP Servers and if you have another account with other server you just add. and add /exchange to the end of my server name (mail.server.com/exchange) then it worked perfectly. You also need to make sure that your smtp port on the exchange server matches the iphone's smtp port and that your firewall won't block it.
No email can not be sent or compuse or reply
After deleting and recreating an account in Mail, you might not be able to send emails even if you can receive them. When you try to send a message, this alert may appear:
"Cannot send message using the server smtp.xxxxx.com"
This happens if the Simple Mail Transport Protocol (SMTP) server, used for outgoing messages, was incorrectly entered with the first account even if it was correctly entered for the replacement account.
Products Affected Mail
Resolution You should first verify that the network connection you're using is the correct one for the ISP that you want mail to communicate with.
  1. Open Mail.
  2. From the Mail menu, choose Preferences
  3. Click Accounts.
  4. On the Outgoing Mail Server (SMTP) pop-up menu, choose Edit Server List.
  5. Delete all entries for the SMTP server that is mentioned in the error, and click Done.
  6. Configure the current SMTP server by clicking Server Setting.
    Note: If you need to use multiple SMTP servers for multiple Mail accounts, see this document.
  7. Send a test message to your email address.
Jun 02, 2009 • Yahoo Mail
My computer refuses to change a message in Outbox to Send, leaving me with a queue ofunsent messages. I can receive incoming clls, but not send any out returner@ntl world.com
Make sure your SMTP (outgoing) server is set properly.
Are you on your own connection - or using a retail WiFi one?
Normally most WiFi servers reject outgoing mail.
You can GET mail - just not send any.
SMTP is blocked.
Pop3 (incoming) is allowed.
To check that the SMTP is set properly -
Open O/E, and navigate to the following screen....
Tools > Accounts > (Highlight the eMail account you are trying to send from).
Then click Properties
Click SERVERS tab.
It should say...
Outgoing Mail (SMTP): __________________________
In the blank it should say something like: SMTP.ntworld.com
(check with your service provider for the correct SMTP setting)
Thanks for using FixYa - if you need further clarification on your question - please use the "continue with this user" option so we are connected in the future.
Thank You!! :D
Grand Canyon Tech
Grand Canyon Tech
