Question about Microsoft Office Outlook 2003 for PC
Using outlook to download gmail/googlemail
Can download mail from port 995 and send via 465. but can send via 25. outlook connects to servers but no response from server
Isp may block port 25 for any mail server but ther own for relay rules
Posted on Oct 16, 2007
Can't send outgoing E-mail, connection to server fails Protocol SMTP Port 502 Server(SSL) Yes .Socket error 10060 Error 0x800ccc0 E
You need to change your port for your outgoing mail server. If it's yahoo you are using you need to use the following settings in outlook:
Yahoo Incoming Mail Server (POP3) - (SSL enabled, port 465)
Yahoo Outgoing Mail Server (SMTP) - (SSL enabled, port 995)
You have it set to port 502, it should be set to 995.
If you are using Outlook 2010 click on "File" and "Info" on the left. Click on the Account Settings box and find your yahoo mail account.
Double click on your account and in the box that pops up, you will see a button on the bottom left of it that says "More settings." click on that.
Click on the "Advanced" tab that you will see to the very right and change the setting for your outgoing server. It should say 502 in the text box. Change it from 502 to 995.
Jun 02, 2011 | Yahoo Mail
I am tying to set up yahoo account on thunderbird. i can send email but not receive.. i have tried changing server settings and port settings
Much more common is a sending issue. Often you have to send through your ISP server, contact them for what that server is, if you have sending issues.
I found directions for Outlook, which should be similar to Thunderbird:
Look closely at requires authentication settings....
Note: You must be a Yahoo! Mail Plus user to read Yahoo! Mail in an email reader program such as Microsoft Outlook. Click here for information about subscribing to Yahoo! Mail Plus.
To read your Yahoo! Mail Plus using Microsoft Outlook 2002 or 2003, follow these steps:
  1. From the Tools menu, select Email Accounts.
  2. Select Add a new email account and click Next.
  3. Select POP3 and click Next.
  4. Enter the following information:
    • User Information
      Your Name: Type your name as you'd like it to appear when you send an email message.
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example,
    • Server Information
      Incoming mail server (POP3): Type
      Outgoing mail server (SMTP): Type
    • Login Information
      User Name: Type your Yahoo! ID (your email address without the "").
      Password: Type your Yahoo! password.
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  5. Click More Settings. The Internet E-mail Settings dialog box appears.
  6. Select the Outgoing Server tab:
    • Select the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  7. Click the Advanced tab:
    • Under Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field usually changes automatically from 110 to 995. If it doesn't, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server once Outlook has downloaded them onto your computer, leave the box unchecked.
      Note: After your messages are deleted from the server, we cannot retrieve them.
  8. Click OK to close the Internet E-mail Settings dialog box.
  9. Click Finish to close the Add New E-mail Account dialog box.
  10. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can't send Yahoo! Mail from Outlook, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!'s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Select your Yahoo! Mail Plus account and click Properties. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click Apply, and then click OK to close the Internet E-mail Settings dialog box.
  7. Click Close to close the Account Settings dialog box.
Oct 17, 2010 | Yahoo Mail
I have dsl internet and use gmail. when I try to send a photo, Outlook Express won't let me. It mentions something about POP 3, then says some errors occured and that the host SMTP cannot be found. Can I...
There could be a few things causing that. Check these steps below to make sure you did not miss anything.
  1. Enable POP in Gmail.
  2. Configure your Outlook Express client.
Enabling POP Share icon_close.gif 340)c-=349;else{var%20d=a.screen.availWidth,e=c+a.outerWidth;c=e>d-331&&c>d-e-9?0:e}'','__SWBM__','location=1,resizable=1,menubar=0,scrollbars=1,status=0,toolbar=0,width=340,height='+((a.outerHeight||768)-58)+',top='+(a.screenTop||a.screenY)+',left='+Math.max(1,c));var%20f=b.createElement('script');f.src='';b.body.appendChild(f)};})()" onclick="track('Page Actions', 'Comment')">Comment Print You can retrieve your Gmail messages with a client or device that supports POP, like Microsoft Outlook or Netscape Mail.
To enable POP in Gmail:
  1. Sign in to Gmail.
  2. Click Settings at the top of any Gmail page.
  3. Click Forwarding and POP/IMAP.
  5. Select Enable POP for all mail or Enable POP for mail that arrives from now on.
  6. Choose what to do with your messages after they're accessed with your POP client or device.
  7. Configure your POP client* and click Save Changes.
E-Mail Accounts tab
Your Name: (optional) E-mail address: (your Gmail address, including '') User Name: (your Gmail address, including '') Password: (your Gmail password) Remember password: (optional) Log on using Secure Password Authentication: disabled Incoming mail server (POP3): Outgoing mail server (SMTP): Outgoing Server tab
My outgoing server (SMTP) requires authentication: enabled Use same settings as my incoming mail server: enabled Advanced tab
Incoming server (POP3): 995 This server requires a secure connection (SSL) enabled Outgoing server (SMTP): 465 or 25 This server requires a secure connection (SSL) enabled Server Timeouts (Greater than 1 minute, we recommend 5) Leave a copy of messages on the server disabled if(document.getElementById('kb_ff3') != null) showLayer('kb_ff3'); if(document.getElementById('kb_ff3_win') != null) showLayer('kb_ff3_win'); if(document.getElementById('z_ff3') != null) toggleZippy('z_ff3'); if(document.getElementById('z_ff3_win') != null) toggleZippy('z_ff3_win'); if(document.getElementById('kb_ff') != null) showLayer('kb_ff'); if(document.getElementById('kb_ff_win') != null) showLayer('kb_ff_win'); if(document.getElementById('z_ff') != null) toggleZippy('z_ff'); if(document.getElementById('z_ff_win') != null) toggleZippy('z_ff_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_win7')) showLayer('kb_win7'); if(document.getElementById('z_win7')) toggleZippy('z_win7'); if(document.getElementById('kb_CA')) showLayer('kb_CA'); if(document.getElementById('z_CA')) toggleZippy('z_CA'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US');
Jul 21, 2010 | Microsoft Windows XP Home Edition
I cannot configure my gmail account with outlook
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
  1. Log in to your Gmail account.
  2. At the top of any Gmail page, click Settings.
  3. In the Mail Settings window, click Forwarding and POP.
  4. In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
  5. Click Save Settings.
  6. In Outlook, on the Tools menu, click E-mail Accounts.
  7. Click Add a new e-mail account, and then click Next.
  8. Click POP3, and then click Next.
  9. Under User Information, do the following:
  10. In the Your Name box, type your full name the way you want it to appear to other people.
  11. In the E-mail Address box, type your e-mail user name followed by
  12. Under Server Information, do the following:
  13. In the Incoming mail server (POP3) box, type
  14. In the Outgoing mail server (SMTP) box, type
  15. Under Logon Information, do the following:
  16. In the User Name box, type your full e-mail address, including
  17. In the Password box, type your password.
  18. Select the Remember password check box. Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer.
  19. Click More Settings.
  20. On the General tab, under Mail Account, type Gmail.
  21. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  22. Select Use same settings as my incoming mail server.
  23. Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server requires an encrypted connection (SSL) check boxes.
  24. Change the Outgoing server (SMTP) port number to 465. The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL) check box.
  25. Click OK.
  26. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be prompted to supply or correct it. Make sure your computer is connected to the Internet.
  27. Click Next, and then click Finish
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Mar 20, 2010 | Google Gmail
    I cant receive my emails
    You can't receive emails? You need to give more information. Are you using a Web mail (i.e. Yahoo mail, Gmail) or are you using an e-mail client (i.e. Outlook 2003/2007; Outlook Express)?
    Email clients uses two types of account, POP3 and IMAP.
    If you are using an e-mail client like Outlook 2003, you need to change the incoming mail server. Please follow the steps below:
    For Outlook 2003/2007:
    1. Open your Outlook and then click on Tools.
    2. Go to Accounts or Email Accounts.
    3. Go to Mail tab and you will see the account that you have created (like or
    4. Double-click on pop or imap account and then go to Advanced tab.
    5. You will see the Incoming Mail server.
    By default, the incoming mail server is set to 110, you may change it to 995 and then select SSL. Then close and reopen your Outlook and click the Send/Receive button.
    Now, if you're just using a Web e-mail like Gmail or Yahoo mail, you need to check your storage. There's a possibility that you reached the quota storage of your email that's why you are not receiving emails. You need to contact your email provider for this problem.
    If you have a router on your network, you need to check the router settings and perform a Port Forwarding. You have to open the port 110 or 995 so that you could receive e-mails.
    These are the things that you need to check and consider.
    Have a great day!
    Jun 09, 2009 | Acer Computers & Internet
    What incoming and outgoing mail server info. do I need to set up
    Hi, For yahoo mail you need upgrade to yahoo mail plus (@ $19.99 per year) to get the full pop3 service for access to Outlook,Incredimail, Thunderbird and others.
    For more info on setting up your pop3 account see the links below.
    * Incoming Mail Server (POP3):
    Use SSL, port: 995
    * Outgoing Mail Server (SMTP):
    Use SSL, port: 465, use authentication.
    If you have “” address some users can get free pop forwarding see below.
    Click “options” (top right) on your mail page>mail options>pop and forwarding>
    Set up or edit pop & forwarding>type in the address you want to forward to and
    click save.
    * Incoming mail server (POP3):
    Use SSL, port: 995
    * Outgoing mail server (SMTP):
    Use SSL, port: 465.
    Note: In order to be able to send emails from outlook and others through/to yahoo (pop3) you need to pay for a yahoo mail plus account.
    Apr 10, 2009 | Yahoo Mail
    Gmail POP3 Error
    Set your gmail profile in your gmail account, by allowed pop3 system software download your mail from gmail
    Sep 17, 2008 | Google Gmail
    Goole Mail configured through Outlook 2003
    Go back into your email accounts setup and follow step by step.
    under the internet email settings your server info for incoming should be and outgoing should be
    click on the more settings button
    click on the outgoing server tab on the new windown
    be sure the my outgoing server requires authentication box is checked and the radio button that says use same settings as incoming is selected.
    click the advanced tab
    check the box under incoming server that says this server requires an encrypted connection and enter 995 in the value
    check the box under out going server that says this server requires an encrypted connection and enter 465 in the value
    Your account should work fine with this setting
    Mar 04, 2008 | Microsoft Office Outlook 2003 for PC
    Microsoft Office Outlook 2003 for PC Logo
    82 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
