Question about Microsoft Windows XP Professional
Javac unable to compile java error or batch file?
Problem to run program in java
  • 3 Answers
First of all you have to set path for your jdk
have you done that???????
if not then go to youtube.com and search for that vedio.
if yes, then i think you have not named the project properly
when you are to save your project, name it in the "name of the main class.java"
for example:
class Manju
   public static void main(String arg[]s)
       ___________________________;
save it as Manju.java and then compile
no matter what other classes are being related to the project.
this much i only know
if you wanna contact me or chat with me, my email id is linushwahs@gmail.com
Posted on May 16, 2009
  • 2 more comments
  • draccule May 16, 2009
    one more thing if you dont find out the vedio contact me i have it
    my email id is linuswahs@gmail.com
    not the previous one
    sorry for the spelling mistake !!!!!!!!!!!!!!!!
    my email id is draccule@gmail.com
    you can contact me in any of the above last two ids
    believe me i am not a hacker
    i shall not send you stupid messages
Java Vitual Machine Launcher prompts this message "Could not find the main class. Program will exit" How can I solve this problem? I need urgent assistance.
You need to compile the .java file you have, and run the .class file that is produced.
Open up command prompt, go to your working directory. If your file was called Hello.java: In command prompt type "javac Hello.java". Now, in the working directory, you will see a new file, Hello.class. Run that file by "java Hello.class". Hope this helps!
Thanks for using FixYa
Aug 20, 2011 | Sun Java Programming Language (cdj-275)
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
Ple tell me how to run the "javac" command in my laptop iam already installed the 1 6 version of java, and I set path is "C:Program Files (x86)Javajre1.6.0_16in", "java" command is exetues but java c...
javac is the JavaCompiler, You've downloaded the Java Runtime. You need to download the SDK, which includes javac.
http://java.sun.com/javaee/downloads/index.jsp
Jan 24, 2010 | Sun Java System Web Server 6.1...
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
regards
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
How to run java code in cmd prompt...
javac filename.java to compile and java filename to execute
Mar 21, 2009 | Computers & Internet
JAVAC IS NOT RECOGNIGED AS AN EXTERNAL OR INTERNAL COMMAND OPERABLE PROGRAM OR BATCH FILE''
Your PC - not the calculator - printed this message. It means that the PC tried to execute the Java compiler, but couldn't find the program. Either the Java compiler is not installed, or the PATH environment variable is not set correctly.
To install the Java compiler follow the instructions for installing J2SE at java.sun.com To fix the PATH environment variable: right-click on My Computer, select Properties, select Advanced System settings, select environment variables, edit or create a new variable called PATH in the system or user settings with the path of the javac.exe program. This is often found in c:Program FilesJavain (it's in a java...bin directory somewhere)
Mar 02, 2009 | Texas Instruments TI-83 Plus Calculator
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
Cannot install/uninstall Java
hi,
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Microsoft Windows XP Professional Logo
117 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
