Question about Saws
Connecting new start switch to AEG ac single phase
Connecting new replacement start switch (rated for 1.1kw motor bought from kaylo uk ltd) to AEG ac single phase motor(EB121D 60/70,1-mot1.1kw DM 067 875) driving a Mafell biberex L wood saw circa1983. Motor has live, neutral, earth + two other black wires. One of these is wired common to neutral in the old start switch, the other black wire?? How do i connect this to start switch - with live (solenoid cuts this line only), neutral, earth to the motor with the extra black wires?
rockitman187
  • 2559 Answers
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
SRF518
  • 232 Answers
SOURCE: need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Posted on Oct 20, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 29, 2017 | Carrier Heating & Cooling
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
How to change a 3 phase to single phase motor
You cannot change a 3 phase motor into a single phase motor because the windings are different in these motors. You need to buy a single phase motor to replace the 3 phase motor.
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Jun 15, 2011 | Air Tools & Compressors
I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
Nov 05, 2010 | Garden
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
I would like to connect a pressure switch to the motor starter
hi! there, single phase compressor motor need a starting capacitor base on the rated capacity in horse power,you can check this on the tag of the compressor motor how many horsepower was indicated,it should be for single phase motor starting capacitor has a capacity of micro farads.for a 1 horsepower = 15 to 18 micro farads stating capacitor if you have more than 1 horsepower you can basically proportion the value of capacitor you need or ask the dealer how much capacitor you need on your motor the connection of pressure switch with a four terminal should be connected both on common line L1 and running capacitor line L2 .if you open the cover of pressure switch there are 4 terminals,2 terminals are connected when normally close or no pressure they connected on series connection on the common line one terminal connected to common line of the compressor and the other terminal on L1 to the pushbutton switch to L1 supply line.the 2 other terminals also connected in series withe line capacitors L2 to yhr power supply line.hope this will help you a lot.just rate my fix thanks a lot.
Apr 20, 2010 | Air Tools & Compressors
Is posible run a single phase electric motor from a source three phase 120/208 wye connection the motor is rated 230 volts AC
It is indeed possible to use ONE Phase to run a motor, You simply use One Phase and Neutral. BUT ONLY if the 3 phase is Double, more or less, the required usage Voltage, EG: 440 3 phase, will be OK, for 220 single phase, . But 220 3 Phase,will not run a 240. single Phase. So in your case is suspect not, it really will do no harm to try though. it just wouldn't work, if not enough "juice", be careful.
http://en.wikipedia.org/wiki/Three-phase_electric_power
Feb 24, 2010 | Heating & Cooling
I bought a new electric motor ml7112 series and
does it have capacitors on the motor (humped covers on top) If not then it may ot be a single phase. also on the motor name plate or on the inside cover of the connector box it should have wiring diaphragm that will tell you how to wire the motor, single phase motor will show 2 line connections and a three phase will show 3 line connections,,, line connections are represented by L-1 L-2 L-3 these mean incoming power.
Jan 24, 2010 | Electric Air Tools & Compressors
The wiring of an AC motor panel
if you can let me know exactly what it is you are trying to achieve I will be able to help out. For instance do you need the motor to run continously, does it need to have variable speed, is it single or three phase, what rating is the motor
daz
May 07, 2008 | Black & Decker 19" Electric Lawnhog...
Saws Logo
279 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
