The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
