Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
DVD connection I connected my dvd player to my tv. The video play on input video one and the audio plays on input video two. I checked the audio connections and they are correct?
  • 979 Answers
Go back and check your connections again, sound like they are wrong...accordianman
Posted on Feb 15, 2008
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Buzz in Samsung Digital when DVP-NS57P Sony is played back?
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
