Question about OKI C5510 MFP All-In-One Led Printer
How to reset toner drum for the oki c5510 mfp?
  • Anonymous May 18, 2009
    that works for the old Oki's but not for the C5510mfp
  • moodo May 24, 2009
    i have the same problem its not working with c5510mfp because there is no display on printer it self
  • OKI Master
  • 4,338 Answers
. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
Oki C5350 error 563
563 I usually drum code reset, some OKI machine have sensors in the side frames they look like a little round window, clean with Q tip, I will assume you have replaced the drum, right?
May 05, 2014 | OKI C5510 MFP All-In-One Led Printer
Oki C5510 'Unable to detect printer'
If you have all the led's lit and they are not flashing it means the printer is in download mode. In other words its waiting for you to download new firmware. Look at OKI's site and find the firmware and follow the instructions. That's why you cant install drivers because the printer no longer knows what it is!
Jun 17, 2017 | OKI C5510 MFP All-In-One Led Printer
Is there a Windows 7 driver for a OKI C5510 MFP?
No not as yet i think there still having problems with vista drivers.
Nov 23, 2009 | OKI C5510 MFP All-In-One Led Printer
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Nov 08, 2009 | OKI C5510 MFP All-In-One Led Printer
Computer cannot see Oki c5510 in network.
It's very possible that with a reboot of the printer and/or your router that DHCP assined a new IP address to the machine. Look in your router settings for the active clients and look for the IP address of the printer. Than go into your printer management within Windows, check the IP address assigned to the printer and change it to match the IP address you found on the router. It's happened to me before and it can be very frustrating.
Aug 08, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 - when printing on photo paper, makes goo all over and photo does not print properly??
you must choose the thickest media type possible at the printer and on the pc. your fuser is not fusing properly causing toner to goo on the roller, changing to thick paper increases temp and slows printing to ensure bonding. some coated papers do not work well with OKI printers. you should check mnf website for specs and recommended papers types
Aug 04, 2009 | OKI C5510 MFP All-In-One Led Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 MFP All-In-One Led Printer Logo
3,509 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
